Buying svt rear brake kit
Hey everyone I'm buying a rear svt setup off of a member on fj and I'm just curious as to what all I should make aure he includes... Not too sure as what I actually need to do a full swap... Ne info would be appreciated... As most of u know my cars an ST so they'd be going on that!!
Thanks
Korby
07 ST 23D • MBRP 2.25 cat-back • cfm 67mm TB • K&n Typhoon • Massive poly dogbone insert • Massive BSD • FRPP Dynamic springs & struts • carbon fibre shift boot & brake boot • SVT HVAC controls • steeda short throw shifter • Tinted w/ brow • SOON TO BE BOOSTED •
(10-06-2011, 06:37 AM)MuskokaZX3 Wrote: Hey everyone I'm buying a rear svt setup off of a member on fj and I'm just curious as to what all I should make aure he includes... Not too sure as what I actually need to do a full swap... Ne info would be appreciated... As most of u know my cars an ST so they'd be going on that!!
Thanks
Korby
The only critical thing that you could not source elsewhere (or isn't already on your car) is the caliper bracket. And obviously other than that the rotor is the biggest difference ... your existing spindle, caliper, and brake line should all be good if he happens not to send them to you.
BTW - if the brakes are coming off an actual SVT the brake lines will be no good to you; if it's the Ford Racing SVT kit for regular foci, then the brake lines would be useful to have.
Off an actual svt... And he's got like 80% steeda pads and rotors... Shipped for 420... So just make sure i reference the mounting bracket...
  Tsb: Rear Brake Squeal CanadaSVT 1 1,885 09-20-2006, 11:52 PM
Last Post: BerinG
  Rear Brake Shoes focuzedn2o 6 3,335 05-10-2006, 03:04 AM
Last Post: focuzedn2o
  Rear Brake Noise TonyDee 5 3,196 03-03-2006, 04:25 AM
Last Post: 01-yellow-ZX3
  Need Help! Rear Brake Light Stay On At Drive! Black_ZTS 3 2,331 11-14-2005, 07:03 AM
Last Post: Black_ZTS
  Rear Brake Shoes/drums - How Long Do They Last? xappie 1 1,761 04-06-2005, 02:39 AM
