  • 2 Vote(s) - 5 Average
(05-16-2012, 01:23 AM)buzz2.0 Wrote: wow engine bay looks nice white...probably wont stay white long....but its lookin good...keep it up, it should be on the road soon.....
It would if it were my car.
Yeah but only 'cause you're not normal.
[Image: 20120515_154321.jpg]
[Image: 20120515_154331.jpg]
[Image: 20120515_154348.jpg]
[Image: 20120516_180825.jpg]
[Image: 20120516_180936.jpg]
[Image: 20120516_180910.jpg]
You are going to have soo much fun with that little toy. Looking good. Keep it up.
man I love those wheels.
nice! whens the rally??? lol, once you have it road worthy we should go up north, find some dirt roads and test it out!!Big Grin
[Image: 20120518_110749.jpg]
some more wiring to finish.
[Image: 20120519_150134.jpg]
[Image: 20120519_150219.jpg]
Soo close Leo!!!
still need to do some gauge wiring, taillight wiring, power steering fluid change, mtx fluid change, engine oil and get 91 octane in jerry can from gas station.
possibly, i will try to butcher wiring to have drl to come on high beam sides, not on low beams. wish me luck.
everything is good and cranks but i am not hearing fuel pump whining..
checked fuel fuse and it gets power, relay clicks when key is on.
at first i was getting p1233 which is FPDM disable/ offline.
Possible causes:
Inertia fuel shutoff (IFS) switch needs to be reset.
Open FPDM ground circuit
Open circuit to FPDM PWR RLY
Open FPDM PWR circuit
Open or shorted FPM circuit (engine should start).
Damaged IFS switch.
Damaged FPDM PWR RLY
checked inertia switch and it was in, not popped out, i am not sure if it stays in or out.
and i might switch high beam relay to this fuel relay to see if it fixes problem.
Check all your grounds to the wiring to the fuel pump. I had the same code and just turned out be a bad ground right by the safety ennertia switch
...because RACECAR! haha
found problem.
Diode #1, everything works now
[Image: 2010-04-22_185833_2010-04-22_135758.jpg]
Sweet Leo... Running by the end of the weekend??
not really..water pump housing to block and thermostat housing to block has some minor coolant leaks.
and i used diode #2 in diode #1 slot, so missing diode.
and local ford dealers has nothing in stock.
they will have by tomorrow, i hope.
that's an amazing Focus WRC
i can t wait to see this thing done, this is going to be one crazy focus!
Focusmanfocus must have some of these diodes.....
car is already up and running strong at 5psi.
i am going to up the boost 11psi and send datalog to randy sometimes this week.
look what my friend done to my car..
oil cooler...............
[Image: 20120528_160342.jpg]
Some friend. How did that happen?
looks like trying to get the tappered brass fitting to go all the way in ....
  My first build thread, 2000 ZX3 turned RS MikkelRS 59 32,666 07-16-2016, 02:56 PM
Last Post: MikkelRS
  Few new parts, possible build thread? jtdanks 40 27,660 05-11-2013, 09:49 AM
Last Post: jtdanks
