Canadian Ford Challenge July 13th & 14th (ST. Thomas Drag Way)
Just wanted to give the Focus Crowd a Heads up on The Race going on @ St Thomas this weekend coming up. Ford cars only & Engines must be a ford power plant. It will be on a Pro .500 Tree which is exciting to race on. Friday all day is Test and Tune, Sat will be the race day with qualifying in the morning and eliminations around noon. Camping Friday night is free.
We created a FWD Bracket class that most Focus,contour and Fiesta owners would be able to run. Here is the info
Front Wheel Drive Ford (Bracket class)
Rules & Regulations
- Qualifying is based on The best reaction time. ( #1 qualifier) You will then be put on a Sportsman ladder for eliminations.
- FWD Ford is a bracket class created for Street cars with Radial tires. To compete with a full race Rear wheel Drive bracket car with a Fwd street car is tough. FWD Ford pairs racers with similar set up opponents. FWD Ford uses a 5/10ths Pro Tree” start system. Any Front wheel drive Ford vehicle is permitted. Any modifications, any vehicle weight, or power adders are permitted. Trans-brakes and 2-steps are permitted. Delay boxes, Throttle-stop, crossover boxes, or any “reaction-time related” electronic aids strictly prohibited. No restriction on tires.
- The fastest qualifying ET permitted in FWD Ford class is 10.50. Any qualifying pass faster than 10.50 will be disqualified and will not count. Competitor will be permitted to requalify (if additional qualifying rounds are left) slower than 10.50.
NHRA Safety rules apply. FWD Ford will be ran on a Pro .500 Tree
Here are some of the other Classes that will be going on durring the event.
Bracket Classes
Ford Comp 1 (10.49 & Slower Bracket)
Rules & Regulations
- Ford Comp 1 is based from OSCA open Comp format, which uses a ” 5/10ths Pro Tree” start system. Any Ford “door slammer-type” vehicle is permitted. Any modifications, any tires, any vehicle weight, or power adders are permitted. Trans-brakes and 2-steps are permitted. Delay boxes, Throttle-stop, crossover boxes, or any “reaction-time related” electronic aids strictly prohibited.
- The fastest qualifying ET permitted in the Ford Comp 1 class is 10.50. Any qualifying pass faster than 10.50 will be disqualified and will not count. Competitor will be permitted to requalify (if additional qualifying rounds are left) slower than 10.50.
NHRA Safety rules apply. Ford Comp 1 will be ran on a Pro .500 Tree
Ford Comp 2 (10.49 & Faster Bracket)
Rules & Regulations
- Ford Comp 2 is based from OSCA Pro Comp format, which uses a ” 4/10ths Pro Tree” start system. Any Ford “door slammer-type” vehicle is permitted. Any modifications, any tires, any vehicle weight, or power adders are permitted. Trans-brakes and 2-steps are permitted. Delay boxes, Throttle-stop, crossover boxes, or any “reaction-time related” electronic aids strictly prohibited.
-The fastest qualifying ET permitted in the Ford Comp 2 class is 7.50. Any qualifying pass faster than 7.50 will be disqualified and will not count. Competitor will be permitted to requalify (if additional qualifying rounds are left) slower than 7.50.
NHRA Safety rules apply. Ford Comp 2 will be ran on a Pro .400 Tree
Street Ford (Radial Tire Bracket class)
Rules & Regulations
- Street Ford is a bracket class created for Street cars with Radial tires. To compete with a full race bracket car with a normal radial street car is tough. Street Ford pairs racers with similar set up opponents. Street Ford uses a 5/10ths Pro Tree” start system. Any Ford vehicle is permitted. Any modifications, any vehicle weight, or power adders are permitted. Trans-brakes and 2-steps are permitted. Delay boxes, Throttle-stop, crossover boxes, or any “reaction-time related” electronic aids strictly prohibited.
Tire Rule
-Any Mickey Thompson, Hoosier or M & H Drag radial strictly prohibited. Any Normal Radial or Drag related radial other then- MT, Hoosier & M&H Permitted.
- The fastest qualifying ET permitted in the Street Ford class is 10.50. Any qualifying pass faster than 10.50 will be disqualified and will not count. Competitor will be permitted to requalify (if additional qualifying rounds are left) slower than 10.50.
NHRA Safety rules apply. Street Ford will be ran on a Pro .500 Tree
Heads up Classes
All Motor Street Rules
Body & Chassis
-Ford’s Only
-Lexan/Plexiglass Window replacements prohibited
-Head lights & Tail lights required to be functional
-Full interior required (Must have upholstered door panels, dash, carpet 2 front seats, rear seats may be removed but covered rear seat delete style)
-Stock style suspension required front & rear (Bolt in replacement components and traction devices allowed.
-Ladder bars / 4-links prohibited (must retain unmodified rear frame)
-Stock fire wall and location required
-No wheelie bars
-Aftermarket functioning hood scoops prohibited for carburetor applications unless oem equipped
-Ram air induction may only be from behind oem bumper / Grille (No inlet holes or scoops on the outside of the body)
-There will be min race weight of 2900 lbs
-Front Bumper must retain factory lower grille opening (Filled lower valence prohibited)
Engine
-Motor must be Ford powered (281, 289, 302, 351, 4.6 Modular, 5.4 Modular, 5.0 Modular based engine plants)
-Aftermarket push rod based engine block’s permitted (Dart, Ford Racing etc)
-Stroker kit’s permitted
-Naturally Aspirated Only (Power adders strictly prohibited)
-No restriction on internals
-Both EFI & Carburetor Combo’s permitted
Drivetrain
-Standard Tremec based Transmissions permitted (Clutch less Transmission prohibited)
-Any Automatic Transmission permitted (Electronic or Manually shifted)
Fuel
-Any gasoline based fuel permitted
Exhaust
-Full length Headers permitted (cats do not have to be present)
-Mufflers required
-Exhaust must exit within 12 inches of rear diff (dumps under car permitted)
Tires / Wheels
-Any Oem/ aftermarket wheels permitted
-Any D.o.t street Tire, Aftermarket Slick, Drag Radial and Front skinnies permitted
Street Legal requirements
-Car must be plated & Insured (With up to date sticker)
All Motor Street is a heads up class created for Canadian ford challenge. Even though Race parts are permitted the way to regulate a car that is Driven on the road is to have it registered & Insured. This will be the most effective way to keep the class from getting out of control.
NHRA Safety rules apply. All Motor street will be ran on a Pro .500 Tree.
Power Adder Street Rules
Body & Chassis
-Ford’s Only
-No wheelie bars
-There will be a Min race weight of 3000lbs
Engine & Induction
-Single Power adder (Blower, Nitrous, Single turbo)
Drivetrain
Fuel
Exhaust
-Full length Headers & Tubular Turbo manifolds Permitted (cats do not have to be present)
-Mufflers required
Tires / Wheels
Power Adder Street is a heads up class created for Canadian ford challenge. Even though Race parts are permitted the way to regulate a car that is Driven on the road is to have it registered & Insured. This will be the most effective way to keep the class from getting out of control.
NHRA Safety rules apply. Power adder street will be ran on a Pro .500 Tree.
King of the Street
Body & Chassis
-Ford’s Only
-No wheelie bars
Engine
-Naturally Aspirated & Power adder combinations permitted
Drivetrain
Fuel
Exhaust
-Full length Headers & Tubular Turbo manifolds permitted (cats do not have to be present)
-Mufflers required
Tires / Wheels
-Any D.o.t street Tire or D.o.t Drag Radial permitted
King Of The Street is a heads up class created for Canadian ford challenge. The way to regulate a car that is Driven on the road is to have it registered & Insured. This will be the most effective way to keep the class from getting out of control.
-Racers be prepared for a 20-30km Cruise pending on race schedule
NHRA Safety rules apply. King of the street will be ran on a Pro .500 Tree.
There will be a Car Show also going on Saturday for the show & Shine guys
2005 GT 5.0 Coyote (All Motor) 10.62 @ 130 Mph
2011 Fiesta (All Motor) 15.97 @ 84 Mph
Wow no interest here? If I had my focus I would be all over this.
DruZX3 You Tube Page
My Rides on Car Domain
I might swing by Saturday.
It's supposed to rain sat. But if it changes I may race mine. Guess we'll see...
2000 zx3 5 speed, stock.... For now
Forecast has changed, no rain for sat now
Did anyone end up going to this? I was in Dover for Friday 13th.
A Stock SVT Focus won the class
  Massiv Monday, July 14th 2008 Focus man. Focus. 59 19,944 07-16-2008, 10:30 PM
Last Post: ZX3_2NV
  Formula Ford Show And Shine - July 20th phased_focus 14 5,537 06-11-2008, 12:44 PM
Last Post: NikiterZTS
  Ford Day At St. Thomas Dragway - Aug 15th @10am GapBoyPCS 10 3,707 08-10-2004, 10:36 PM
Last Post: BrooksZX3
  Maple View This Wed July 14th ANTHONYD 34 14,434 07-15-2004, 07:35 AM
Last Post: scoobasteve
