sunroof switch
anyone have a spare sunroof switch and wants to get rid of it?
Its the same as a window switch Auto wreckers
(08-05-2012, 03:01 AM)muttsnutts Wrote: Its the same as a window switch Auto wreckers
I know that quite often the same part can have two different part numbers, so this is not a comment on the above - but current Ford parts listings show the following:
Window switch (part no. 7S4Z14529C) @ 15.83 USD
Sunroof switch (part no. 4S4Z14529DA) @ 31.11 USD
The fact that both numbers are 14529 suggests they might be interchangeable, although the suffix C vs DA is probably also significant.
Good luck.
if that pic is actual switch, then switch looks different and connection looks different.
(08-04-2012, 02:41 PM)rnzo86 Wrote: anyone have a spare sunroof switch and wants to get rid of it?
My apologies its not the same it clicks twice both ways and has different arrows on the button. Anyways if your still looking for one I have one just pay the postage. Part numbers I can see are 0316 2753 98AB 14529 1M19
K808X Theyre the numbers I can see on the switch
I cant put the pictures on here for some reason but can email them to you if you like
does it work though? cuz mine the down button work but it doesnt open all the way and the up button doesnt work at all
The fact that it doesn't open all the way suggests there is a mechanical problem = did you try using the little crank handle = does it operate okay when you open and close by hand?
it does open but not all the way just slightly I posted a video of how it opens back in May I think
No it doesnt work thats why im sending it to you Huh
Of course it works But looking at your problem its not the switch. If you want it I have it, just pay the postage
Sorry - didn't see the video - but I think you missed my point. Question: are you able to open the sunroof fully, using the handcrank?
If yes, then you are probably right it is a electrical problem. But if not, then you may have a mechanical problem that is stopping your sunroof from opening.
I think in terms of diagnostics you may wish to eliminate any mechanical problem before assuming it's electrical.
