SVT fuel pump upgrade?
Need some help deciding to upgrade my stock 2001 focus fuel pump to a SVT fuel pump??? Mine currently works fine, just have the opportunity to upgrade it, so I just want to know if its worth swapping out the stock one.
...because RACECAR! haha
(08-09-2012, 02:03 AM)stupica1 Wrote: Need some help deciding to upgrade my stock 2001 focus fuel pump to a SVT fuel pump??? Mine currently works fine, just have the opportunity to upgrade it, so I just want to know if its worth swapping out the stock one.
ya buy mine Smile hahaha
What hp are you aiming for - what injectors?
42lb injectors. and looking to go turbo next month or so. will be around 200whp ish range.
(08-09-2012, 08:04 AM)stupica1 Wrote: 42lb injectors. and looking to go turbo next month or so. will be around 200whp ish range.
I have 42 lb injectors and close to 200 with my JRSC - no problem with fuel delivery on the stock Zetec fuel pump. Having said that - if you can get the pump inexpensively and the tank is out of the car already, might be a worthwhile upgrade - but before you do - read this:
turbo tom's opinion on Focus fuel pumps.
  Is it a big job to replace a fuel pump? FocusJetLi 12 7,839 07-27-2010, 03:57 AM
Last Post: GFXjamie
  Wretched Fuel Pump Mason 7 2,263 03-28-2007, 06:39 AM
Last Post: mpcv2000
  2005 Ford Focus - Dead Fuel Sender & Pump! NefCanuck 26 10,140 10-19-2005, 05:39 AM
Last Post: NefCanuck
  Fuel Pump Sakic #7 6 2,761 10-04-2005, 11:21 PM
Last Post: Flofocus
  Fuel Pump Replacement ZX3TUNR 1 1,356 08-11-2005, 09:49 AM
Last Post: schade
  Recalled Fuel Pump And Sender DRyanC 18 7,055 05-11-2005, 02:22 AM
Last Post: skifreak69
  My Focus Is Hesitating And The Fuel Pump Recall Fingers 9 2,998 04-27-2005, 08:27 AM
Last Post: NOS2Go4Me
  Ot: Fuel Pump Recall Focus Is Art 7 2,731 06-03-2004, 02:09 AM
Last Post: BerinG
  Fuel Pump Recall Flofocus 13 4,239 05-21-2004, 11:46 PM
Last Post: 2001 ZTS
