Throttle-body spacers
are throttle body spacer good to have ?
(12-22-2012, 02:35 AM)rnzo86 Wrote: are throttle body spacer good to have ?
I'm also looking at a throttle body spacer. From reading up on them it should give more pep on the throttle with small gains to horsepower and torque. I'm still on the fence about, waiting to see if anyone has one on their Focus and can give some real feed back on it.
2003 ZX5
"I feel like a silver bullet"
SVT wheels
SVT suspension
AEM intake
With a hint of dip
[Image: 158491.png]
I am skeptical, no very skeptical, that a throttle-body spacer would do much. Back in the old days, maybe, when an insulator allowed the carburetor to be a little cooler, it may have had a tiny effect. With today's fuel injection injecting fuel right near the valve, the only benefit I can see is more money for the seller.
Install a K&N cold air kit and a less restrictive exhaust (like Borla). Then you will notice a little more power gain not to mention a nice little roar when you step on the gas.
However, if you are really convinced by these anecdotal sales references, why not build your own (just kidding - not everyone has access to milling machines.)
I have one kicking around in a box some place...
Not convinced it did anything, but was installed at the same time as the intake tho
Useless once you upgrade to a 65mm TB which is your best bang for your buck after an intake
(12-22-2012, 03:57 PM)SL8RZZX3 Wrote: I have one kicking around in a box some place...
I put one on my 2.3D Fusion - I didn't notice any difference. The only thing that happened actually was the longer bolts that came with it wouldn't hold tight (at least not with OE torque) and one time it even started to leak at the tb during a run at Watkins Glen. I took it off at that point and went back to stock. Personally I will never bother with one again.
IIRC these were first introduced as a performance upgrade to GM's early single point injection where one or two large injectors replaced the carb. I could sort of see how that might help there, but I don't really know if it did or not.
Edit: I have both a Steeda CAI and TB spacer for the 2.3 Duratec (also fits 2.0) real cheap if anyone wants them.
  Throttle Body - Worth The Hasel? Alec Brandon 15 5,690 04-06-2007, 04:17 AM
Last Post: SmokeBCBuDZ
  Help: Throttle Body Question focus19 4 2,204 10-29-2006, 03:20 PM
Last Post: NikiterZTS
  Throttle Body snorcus 16 4,042 10-01-2006, 01:49 AM
Last Post: Drivesthebeast
  Throttle Body Spacer focusonthis_88 2 1,430 09-05-2006, 09:38 PM
Last Post: NOS2Go4Me
  Throttle Body Tps Guide ZX3TUNR 0 1,152 08-21-2005, 08:59 AM
Last Post: ZX3TUNR
  Bbk Throttle Body Installed skifreak69 2 1,591 05-23-2005, 03:23 PM
Last Post: skifreak69
  Fc Throttle Body Install? SL8RZZX3 11 3,393 05-22-2004, 03:16 AM
Last Post: darkpuppet
