rear disc spindles
anyone know if the advancetrac rear spindles are the same as the SVT??? i have this as a part number for an SVT rear spindle 98AZ4A013AA, can't seem to find a different one for advancetrac.
I believe the SVT, ST, and all advance trac spindles are the same.
I had ST spindle's and just added the caliper bracket and rotors to convert to SVT.
(02-17-2013, 03:44 AM)castone Wrote: I believe the SVT, ST, and all advance trac spindles are the same.
great, thanks. i'm under that impression too, but i just want to make sure because I want to keep the smaller advancetrac rotors
I think this is all correct - AdvanceTrac rear brakes are exactly the same pieces as the 05-07 ST brakes which should make getting replacement parts easier to figure out. The other difference between SVT and AdvanceTrac / ST rear brakes is that the SVT has the two-piece brake line setup versus a one-piece for the ST/AdvanceTrac
The caliper bracket on the Rear of the SVT is also different to accommodate the larger rotor, but the do share the same caliper.
(02-18-2013, 07:33 AM)lonewolf Wrote: The caliper bracket on the Rear of the SVT is also different to accommodate the larger rotor, but the do share the same caliper.
Thanks
  advances traction control rear disc's zx3wantobesvt 5 3,958 09-07-2013, 03:29 AM
Last Post: drunkinmonkey
  Rear Disc Brake Conversion Parts Needed? castone 11 7,161 03-23-2010, 11:07 AM
Last Post: castone
  Need Help With Rear Disc Brakes redsvtfocus 6 3,245 06-22-2005, 09:41 AM
Last Post: redsvtfocus
  Rear Disc Conversion 2001 ZTS 3 2,372 04-04-2005, 03:50 PM
Last Post: Zoom
