Timing belt replacement
Planning on replacing my timing belt, pulleys and tensioner this weekend, I found some youtube videos and instructions on how to do it. Any tips and suggestions? Is there a torque specification for the pulleys and tensioner when installing them? Thanks
2003 ZX5
"I feel like a silver bullet"
SVT wheels
SVT suspension
AEM intake
With a hint of dip
[Image: 158491.png]
just as long as there tight your pretty well good to go. the tq on those isnt huge
just remember to get a new valve cover gasket aswell
(05-22-2013, 02:43 AM)Lucster1000 Wrote: Planning on replacing my timing belt, pulleys and tensioner this weekend, I found some youtube videos and instructions on how to do it. Any tips and suggestions? Is there a torque specification for the pulleys and tensioner when installing them? Thanks
Since labour is the biggest part of the job, you might want to spend a few bucks more and get a premium belt - like the Gates T294RB.
Already replaced my valve cover gasket, one less thing. All my parts are motorcraft that I got from the dealer.
2003 ZX5
SVT wheels
SVT suspension
AEM intake
With a hint of dip
[Image: 158491.png]
Do I need any special tools to do the timing belt? Just thought of this now.
2003 ZX5
SVT wheels
SVT suspension
AEM intake
With a hint of dip
[Image: 158491.png]
Yea a cam tool. http://focus.c-f-m.com/freeshippingaemca...st170.aspx
your gonna need another gasket depending how new/old it is...you have to take the valve cover off to do the timming belt.. you need the cam tool (see above) to stick in the end of the cams to keep the timming while you change the belt
and do your absolute best not to rotate the crank any. if you do that youll have to find TDC agian
what you can do for a tip is take you valve cover off and stick a ratchet on the crank and rotate the crank until the cams are linned up and stick the cam tool in, after that you can loosen the tensioner and take the belt off and what ever else your changing and everything should be the same and a pretty easy swap over
  2004 SVT Timing Belt Replacement Eddz4 2 1,990 07-27-2013, 10:53 AM
Last Post: NoiSeeVT
Question Timing Belt Change heelchain 17 9,479 03-17-2013, 11:13 PM
Last Post: heelchain
  Timing belt jtdanks 4 2,310 10-03-2012, 09:29 AM
Last Post: kc focus
  Timing belt problems! stupica1 7 3,822 09-11-2012, 11:40 PM
Last Post: stupica1
  Timing or Cam Belt ?? pavlito24 3 1,989 08-15-2011, 09:52 AM
Last Post: Focus man. Focus.
  Timing Belt or Timing Chain dragerboat 2 2,574 05-07-2010, 10:07 PM
Last Post: dragerboat
  When To Replace Timing Belt? Just4Derek 3 1,989 01-06-2007, 07:04 AM
Last Post: ANTHONYD
  Timing Belt dannyq 5 2,322 07-24-2006, 01:45 AM
Last Post: NOS2Go4Me
  Timing Belt 01-yellow-ZX3 17 7,812 03-28-2005, 12:46 PM
Last Post: 2001 ZTS
  Timing Belt Wearing Funny? rubberman 13 4,353 03-23-2005, 03:13 AM
Last Post: 01-yellow-ZX3
