pcv hose or tps?
So my car has been stumbling at idle. I will come up to the lights and it will feel like its going to stall out. The rpms dip well below where they should be. But normal driving its fine. Also when I pop it into neutral it feels like its going to stall and then is fine. Any ideas what it might be?
pcv hose
Thought so. Time to bend over for ford dealer pricing.
My 02 was doing the same thing and it was the coil pack wiring, some of the wires were exposed right before the plug.
Here's what it looked like(not my thread but same issue).
http://www.focusfanatics.com/forum/showt...p?t=209172
i second the coil pack. Had the same issue, replaced the coil pack, wires and plugs and worked flawless.
...because RACECAR! haha
By chance I have a coilpack and wire coming in soon hopefully that fixes it but I'm going to do,the pcv hose to just in case.
Pcv hose broke on my car and it did the same thing
