My first build thread, 2000 ZX3 turned RS
Ya if you are using stock cams then the sto k springs will be good. If you are going to use an aggressive cam then upgrade the springs.
I upgraded my springs lol. but to each there own I guess
I'll probably end up upgrading them. Cost adds up quick even when doing a budget build haha.
I had a chance after work to fab up a bit of my intake adaptor, so far so good, i still have a bit of engineering to do to make it more usable and to clear the oil filter.
Got the knuckles all painted and ready for bearings n hubs Smile
Looks good
So looks like the mark viii IRS is about 1.5-2" narrower than the focus. And it fits in the back hahahaha.
lol that's awesome .
I've decided to use a different slightly smaller brake setup, 07 ford edge 12.6" rotors and Lincoln LS dual piston calipers, I've designed the caliper bracket adaptor, now its just a bit more machining and done Smile
Nice work!!!
sweet dude!
Considering the price of some of the big brake kits for the foci or Mazda 3, I may start making them on request. Depending on bolt pattern and rotor size choice.
Seen you the other day on Barton/centennial . You were hauling something In the trunk
Yea I was carrying a pt cruiser rear axle for a customers car haha. My car has seen a lot of rear end lately.
Got my prototype caliper brackets done. 1" thick cast aluminum. Thicker than the knuckles the calipers came from, should be strong plenty.
Subframe disassembled with the aluminum diff. Its amazing the size of bolt they use for control arms, then 4 little dinky 15mm bolts to mount it all to the car.
Rear subframe painted and clean Smile
Cleaned up diff and coated with color
New rims with front knuckles n brakes... Looks like I need bigger brakes again :/
After a 34 day work week and a 4 day weekend, I have some time off to at least fit the rear end and get more swap parts made up.
I got a pair of solid IRS subframe mounts made:
Made up a block go adapt an external slave cylinder to the t5 bellhousing:
So I've got my car cut apart and fitting the rear axle. I have two rear mounts made anD welded in.
Smile
  wrc rally replica build thread konafocuswrc 710 565,222 04-07-2016, 01:03 AM
Last Post: ANTHONYD
  Few new parts, possible build thread? jtdanks 40 27,660 05-11-2013, 09:49 AM
Last Post: jtdanks
