Valve Cover Torque
Does anyone know what the torque is for the valve cover? I can't find it anywhere.
Haynes Repair Manual : valve cover bolts 80 in-lbs
For comparison, 80 in-lbs is HAND TIGHT in comparison as long as you are not cranking on it so if you don't have a torque wrench, go by that.
The Ford shop manual says the same: 80 lb-in. or 9 Nm.
just tighten it by hand by putting the very top of the rachet and turn it till its tight. don't use the handle of the rachet.
'03 Focus SVT
  Valve Cover oldeguy 6 2,080 03-28-2007, 12:06 PM
Last Post: oldeguy
  Replacing Valve Cover Gasket habmann 15 7,681 04-10-2006, 04:08 AM
Last Post: Drivesthebeast
  You Might Want To Check.. Water Under Valve Cover DanielB_ZX3 14 6,276 08-24-2005, 02:57 PM
Last Post: ZX3TUNR
  Valve Cover Gasket Medicman 9 3,776 01-02-2005, 10:31 PM
Last Post: Zoom
