Zx3 Alignment Specs
I don;t have factory suspension so why would I want factory alignment specs?
Since I put new rubber on (215-45-17) I'm rubbing quite a bit. Not sure what the offset is on my rims but can't afford new rims (if that's the problem). So hopefully an alignment and maybe some fender rolling would help.
Yeah, anyway what alignment specs are you guys running? My driving style is like most people: street with the ocasional spirited driving and autox. Are most of you driving with more neg camber in the front than the rear?
Hedman Header
Hi/Flo Cat
Diablo Chip (re-programmed)
Wings West BodyKit
FK Automotive Suspension
Front and Rear Camber Kit
Fuzion ZRi Summer Tires
Speedhut Indiglo Dash
JVC Head Unit
12 Disc CD Changer
Bazooka Base Tube
Injen Cold Air Intake
What drop are you running?
2" I hope.
You shouldn't be rubbing, I'm betting your offset it outside of 42-49 probably a 38 or 40 offset.
