Threads: 60
OK, so I just picked up the new 2005 ZX5. I like the stock stereo, but I wanted to know if I could just hook up an amp and subs without changing the headunit.??? Either that or if I did install the aftermarket headunit, would I loose function of the steering wheel mounted stereo controls. My last Focus had quite a bit of bump on the trunk, and I want it back, its just not the same.
Threads: 529
First off, glad to see you got the new car :D
Now to business. I'd harbour a guess that the new headunits still don't have RCA-outs in the back as well as a "remote" wire or auto-on wire. You'll need both for a correct amp / speaker / sub connection. This means you'll need a new headunit, and you'll need a new wiring harness / adapter (double-DIN methinks on the 05. Paul?).
As for the steering wheel controls, you'll probably find that everything is plumbed into the Focus wiring harness with no differentiation between power / speakers / other wiring, so your best bet is to go with a remote-controlled deck.
Alternatively, you could always mount the deck on an angle facing towards you (hard to do, but nice when done right) as an alternative.
Threads: 166
Or.... you could get an amp with high level inputs. or a line output converter that will convert the signal coming from the rear speakers into an rca output.
there are options for amp turn on as well, you could hook up a switch. or tap into the igniton turn on. im pretty sure the stock decks might allready have a remote turn on wire.
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
Threads: 129
you could always pick up an rca output box from radioshack or futureshop...their like 10 bucks, you wire them into the speaker wires, and then connect the rca's
Threads: 238
YO..
ANOTHER 05 ZX5 ...kick ass!!
I'm at work right now but, if you wanna swap to an aftermarket deck and keep the sterring wheel controls you'll need to get a interface control block...PAC has the universal unit we need,...I got one...just havent installed in my 05 yet..
Threads: 166
Hey paul... where'd you get that PAC controller for and how much. (if you dont mind me asking)
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
