Threads: 115
05-30-2005, 10:15 AM
(This post was last modified: 06-07-2005, 10:19 AM by focusonthis_88.)
My amps just keep turning on and off..It's getting annoying!! Both amps where tested and they work probably.....What could be the problem??
Turbo arrived!
Threads: 238
focusonthis_88,May 29 2005, 08:15 PM Wrote:My amps just keep turning on and off..It's getting annoying!! Both amps where tested and they work probably.....What could be the problem??
[right][snapback]111345[/snapback][/right]
remote wire loose in the cd player harness? at the amp? check all your other connections..
are you getting power to the amp? or is it the power that cuts out?
check your power wire..
check your ground..
check your fuses..
try all those things...
Threads: 142
Threads: 238
Chromey,May 29 2005, 08:33 PM Wrote:Proper Cooling?
[right][snapback]111350[/snapback][/right]
yeh,,maybe your amps are overheating...
Threads: 103
also wires touching. Like the outputs to the subs. would disable the amps as a protection to prevent dmg. stupid crap like that.
2005 Liquid Grey ZX3 RIP
Threads: 178
Either you're putting them into heatsink protection (overheating them), you have a positive and negative touching somewhere, or you're just for some reason not supplying them with enough power (very unlikely)
Threads: 115
I think it's there overheating...because when the car os off for a while when I turn it back on everything works...give it 10 minutes and it's starts again.
Turbo arrived!
Threads: 938
Sounds like overheating...
are they mounted upside down?
Threads: 115
ANTHONYD,May 30 2005, 09:33 AM Wrote:Sounds like overheating...
[right][snapback]111408[/snapback][/right]
No, there mounted in a angle. How could a fix the heating problem? Put little fans?
Turbo arrived!
Threads: 938
focusonthis_88,May 30 2005, 11:35 AM Wrote:ANTHONYD,May 30 2005, 09:33 AM Wrote:Sounds like overheating...
[right][snapback]111438[/snapback][/right]
That's one way.
They shouldn't be overheating at all though.
Unless there is something wrong. My amp is mounted upside down, gains wide open. Never overheated once. :huh:
Threads: 115
ANTHONYD,May 30 2005, 11:41 AM Wrote:That's one way.
[right][snapback]111441[/snapback][/right]
Im running 4g wires...could that be the problem? I didn't put my capacitor on yet so maybe there to much power going to the amps.
Turbo arrived!
Threads: 938
focusonthis_88,May 30 2005, 11:46 AM Wrote:ANTHONYD,May 30 2005, 11:41 AM Wrote:That's one way.
[right][snapback]111445[/snapback][/right]
Yeah. I would look into regulating the power going to the amps.
I would PM Microbunny or Malby on this one.
Threads: 166
I seriously doubt it has anything to do with the thickness of the wire. the thicker the better in this case.
What are your gains like. ( 10% 50% 100% whatever)
What is the resistance of the speakers that youre powering
what type of amp(s)
is there anything around the amps obstructing air flow.
Check your battery voltage. alot of amps will shut off if your voltage is below the required. Usually they'll shut down below 11.5 volts.
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
Threads: 115
Could it be my battery that's not giving enough power? My batt died a couple of weeks ago..it got dry! So, could my battery still be not strong enought to power my amps?
Turbo arrived!
Threads: 411
How were your amps running BEFORE your battery crapped out?
Threads: 115
Flofocus,May 30 2005, 12:44 PM Wrote:How were your amps running BEFORE your battery crapped out?
[right][snapback]111470[/snapback][/right]
They where ok.
Turbo arrived!
Threads: 411
focusonthis_88,May 30 2005, 12:46 PM Wrote:Flofocus,May 30 2005, 12:44 PM Wrote:How were your amps running BEFORE your battery crapped out?
They where ok.
[right][snapback]111472[/snapback][/right]
Go buy a new Battery ;)
Threads: 115
Flofocus,May 30 2005, 12:48 PM Wrote:focusonthis_88,May 30 2005, 12:46 PM Wrote:Flofocus,May 30 2005, 12:44 PM Wrote:How were your amps running BEFORE your battery crapped out?
They where ok.
[right][snapback]111473[/snapback][/right]
ya I know! Should I get a dry cell? <_<
Turbo arrived!
Threads: 166
Drycells are nice. but you will be putting alot more stress on your alternator if you get one. Thats why i just stuck with a Optima redtop
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
Threads: 115
scoobasteve,May 30 2005, 01:08 PM Wrote:Drycells are nice. but you will be putting alot more stress on your alternator if you get one. Thats why i just stuck with a Optima redtop
[right][snapback]111482[/snapback][/right]
ok, well I'll look in to it.
Turbo arrived!
