What Is The Root Of This Weird Noise?
I go over a bump and it sounds like I've got a tool box in my hatch that's jumping around... last time I got ford to fix it they said it was the rear linkage, but they won't so much as look at it now with all aftermarket suspension... it only comes from the back. Any ideas? Happened when I had stock suspension too.
If you are hearing a clunking noise is usually a shock bushing worn out, that would be my guess. :blink:
Cruz'n the West Coast
Is your jack secure?
It's not the jack, it's some component in the suspension. If you open the hatch and sit on the ledge and press down, it'll make the sound... kinda like a creaking sound. Not noticible unless you're going over bumps... and being that I live in scarborough, I have the keep the radio loud so it doesn't drive me insane :P
Raine,Oct 2 2005, 05:18 PM Wrote:It's not the jack, it's some component in the suspension. If you open the hatch and sit on the ledge and press down, it'll make the sound... kinda like a creaking sound. Not noticible unless you're going over bumps... and being that I live in scarborough, I have the keep the radio loud so it doesn't drive me insane :P
[right][snapback]146125[/snapback][/right]
Mine moans and groans too.
Use dynamat...Problem solved.
ANTHONYD,Oct 2 2005, 04:19 PM Wrote:Mine moans and groans too.
[right][snapback]146127[/snapback][/right]
I was planning to dynamat this winter anyway. But the weird thing is that it was fixed for almost a year when Ford did it last time. Do the rear bushings wear out that fast? If so maybe it's time to invest in some urethane
Actaully in the last couple of days i have been noticing this sound to.
I hear it went i brake and turn, and when i downshift. Like a clunk/ knock sound from my back passanger side.
How much is it to fix this rear linkage business?
I wish my grass was Emo, so it would cut itself...
Strut Mount??? Our's was doing it to it is a worn out strut mount. This happended on the tempo though :lol:
My Mom Says I'm Special
  Weird Noise When Clutch Is Engaged ZX5chica 10 4,659 06-06-2008, 10:31 PM
  Weird Intake Noise Tantrik ZX3 10 3,819 06-02-2008, 02:33 PM
Last Post: naz
  Rattle Noise And Weird Sliding Motion mustanggt_50 2 2,001 04-18-2008, 01:16 AM
Last Post: CanadaSVT
  Guess That Weird Noise _JC_ 7 2,989 02-14-2007, 06:33 AM
  Weird Noise Raine 1 1,412 06-22-2004, 08:14 PM
Last Post: Stap Boy
