I Have The Turbo Bug
#81
Heard the flashers were ECU code locked.. so you could do cars with ame ecu code.. not sure about VIN..
but still.. dont think you 2 have the exact same code..
ZX3T gone..
So do you run the engines on standard compression ratio as bolt-on turbo applications or not?
[Image: sig16.gif]
chumkila,Jun 18 2004, 08:44 AM Wrote:So do you run the engines on standard compression ratio as bolt-on turbo applications or not?
You definately can run it on standard compression but very easily you can lower your compression by installing the head gasket from the Ford Escape. ;)
Paparoach,Jun 18 2004, 02:17 PM Wrote:You definately can run it on standard compression but very easily you can lower your compression by installing the head gasket from the Ford Escape. ;)
Really?
Really?
Really :D
Obviously running it on standard c/r will be dependant on what power output you are pushing for.
Ford Escape? Sorry i've not heard of that as we don't have it in the UK. :D LOL. What c/r does this headgasktet lower to? Also why use this gasket? Is it multi-layer?
[Image: sig16.gif]
The escape is an SUV....the gasket is thicker...so lowers compression. :D
The exact numbers I am not sure of...
Just used Google to find one. ;)
Are these Escape's all 2.3 ?? We use a Focus 2000 Zetec-E Multi-layer headgasket from Ford for most ZT applications.
[Image: sig16.gif]
chumkila,Jun 18 2004, 10:39 AM Wrote:Just used Google to find one. ;)
The old escape had the 2.0L engine...the new ones use the 2.3 duratec.
B)
[Image: sig16.gif]
