10-05-2005, 07:50 AM
Is the clear plastic lense going back on overtop when you're done?
Ebay Halo Hella Hid Conversion Update
10-05-2005, 08:34 AM
i'd say leave the clear plastic off, and make sure the housing fits the fender and hood before you start to paint everything.
hate to see it come this far and have something little screw the entire project up.
'03 Focus SVT
10-05-2005, 09:01 AM
wow, I thought I was crazy with the glass. :blink: :D
Im sure your not done yet, but that thing has a lot of sanding needed!! Cant wait to see the final project.....
10-05-2005, 12:26 PM
guilty,Oct 4 2005, 09:50 PM Wrote:Is the clear plastic lense going back on overtop when you're done? yeah it is and there will be a body coloured eyelid going on too. One of the main reasons I didn't want to get real hellas or morettas or whatever you call em
MBRP................ check SCT Xcal2 ........ check VF mounts Adj. Dampers ... check Meford's Mom.... sale pending
quick update, I have found some time to work on the lights in between work, moving and my social life so the progress doesn't seem like much in the pictures but let me tell you looks are deceiving.. anyways the drivers side light is pretty much ready for final paint, but before that I need to get my LED clusters for the turns first... anyways pics:
![]() before the final primer ![]() ![]() After the final primer, ***NOTE: the top part of the light hasn't been touched because I an going to be adding an eye brow so that will be covered anyways, I don't want to waste time on it. this is the status of the passenger light. ![]() ![]() that's it for now. The part I am having issues with is getting both lights to look the same ( ie curves and what not ) I might not get them exactly the same but that's what you get for making both lights by hand for the first time. If I do this again I will have learnt a few things from this first run..... Any feed back good or bad is always welcomed
10-26-2005, 05:17 AM
hmm............. :mellow:
I'm kinda wanting to see the final look of it more now, I think your doing a good job so far nass.... Can't wait to see the final product. :D
10-26-2005, 05:20 AM
I'll be very interesdted in how tis will hold up in extreme cold. B)
Good work so far though.....
10-26-2005, 05:27 AM
Flofocus,Oct 25 2005, 07:20 PM Wrote:I'll be very interesdted in how tis will hold up in extreme cold. B) yeah if fiberglass had issues with cold weather, wouldn't bodykits crack and what not on their own? I am not worried about the heat generated from the lights since HIDs run way colder. It's a learning experience to say the least for me and possibly a few others out there. I'm just happy the way things have turned out thus far B)
MBRP................ check SCT Xcal2 ........ check VF mounts Adj. Dampers ... check Meford's Mom.... sale pending nass,Oct 25 2005, 03:27 PM Wrote:yeah if fiberglass had issues with cold weather, wouldn't bodykits crack and what not on their own? Well, this is a whole lot of bondo, which does not adhere well to plastic, bondo at least the pink stuff I see you have been using cracks when its very cold and it gets a good stone hit, etc.... I'm sure everything will be fine, and the good thing about fiberglass is its easily fixable.
10-26-2005, 06:02 AM
hardk0re,Oct 25 2005, 03:37 PM Wrote:nass,Oct 25 2005, 03:27 PM Wrote:yeah if fiberglass had issues with cold weather, wouldn't bodykits crack and what not on their own? Those kits are mostly made out of fiberglass, barely ANY bondo used on those. Im sure the glass part will hold its own, its the bondo that will crack up quickly.
10-26-2005, 06:09 AM
Flofocus,Oct 25 2005, 08:02 PM Wrote:hardk0re,Oct 25 2005, 03:37 PM Wrote:nass,Oct 25 2005, 03:27 PM Wrote:yeah if fiberglass had issues with cold weather, wouldn't bodykits crack and what not on their own? well does it crack from just the cold, or from the cold and flexing?? I don't worry about stones cause the plastic cover will be installed
10-26-2005, 08:27 AM
easier just buying the hellas from the start
10-26-2005, 09:11 AM
ZX3TUNR,Oct 25 2005, 06:27 PM Wrote:easier just buying the hellas from the start You can't buy a sence of accomplishment. Back to your emo cave.
10-26-2005, 09:44 AM
ZX3TUNR,Oct 25 2005, 10:27 PM Wrote:easier just buying the hellas from the start yeah I could have just bought hella lights, but then I'd be riding in the back of a bandwagon instead of driving it, I said from the begining that I wanted something that was my own creation and that no one else would have. Beside why would I pay over 400usd ( correct the price if I am off ) for lights when I can spend half that and have my own lights. like AnthonyD said, back to your emo cave.
MBRP................ check SCT Xcal2 ........ check VF mounts Adj. Dampers ... check Meford's Mom.... sale pending nass,Oct 25 2005, 04:09 PM Wrote:well does it crack from just the cold, or from the cold and flexing?? I don't worry about stones cause the plastic cover will be installed Both. When I made the front grill, it was mostly made of bondo hair filler, I was constantly having to sand it down and refill cracks and s**t. The new grill is a mold of the old one and made mostly of fiberglass & very little amounts of filler, and now it doesnt crack anymore when I shut my hood. I think this is a sweet project man. Good fawkin work. :lol: B)
10-26-2005, 10:23 PM
Flofocus,Oct 26 2005, 12:34 AM Wrote:nass,Oct 25 2005, 04:09 PM Wrote:well does it crack from just the cold, or from the cold and flexing?? I don't worry about stones cause the plastic cover will be installed see it was prolly cracking when you shut the hood cause you introduce some sort of force to the material and when it's cold it becomes britle, but since my lights shouldn't see any sort of force or anything I am hoping that things will be ok. I won't slam my hood close when it's cold out either now that I think of it :) thanks, I think I will be open to making another set of these if someone wants since I know what to do now or maybe tail lights? :)
10-27-2005, 09:03 AM
The primered one looks pretty freakin sweet so far dude... needs some more smoothing tho.
10-27-2005, 11:42 AM
The bondo cracks because the plastic it is stuck to expands and contracts (heat and cold) at a different rate then the bondo itself does. So when they move at different "speeds" you can understand that eventually it splits and cracks.
Run your car, not your mouth
10-27-2005, 11:43 PM
Raine,Oct 26 2005, 11:03 PM Wrote:The primered one looks pretty freakin sweet so far dude... needs some more smoothing tho. are you talking about the top of the light? cause that's getting covered by the eye brow... I could finish that part too but I'd rather not spend time on something that won't be seen
10-28-2005, 01:10 AM
ZOOM,Oct 27 2005, 01:42 AM Wrote:The bondo cracks because the plastic it is stuck to expands and contracts (heat and cold) at a different rate then the bondo itself does. So when they move at different "speeds" you can understand that eventually it splits and cracks. what if it is laid ontop of fiberglass... does that make it better or worse? the fiberglass is not ontop of any plastic besides where it meets the plastic on the sides.
MBRP................ check SCT Xcal2 ........ check VF mounts Adj. Dampers ... check Meford's Mom.... sale pending |
« Next Oldest | Next Newest »
New Halo Headlights On Ebay | SL8RZZX3 | 13 | 6,354 |
11-21-2005, 09:06 AM Last Post: smith21 |
