Threads: 173
Okay folks, looking to pick some brains here before I go to the dealer about this.
05 Focus 2.0L Duratech 27,900km
In the last two weeks the car has been sucking back gas like I would have drilled a hole in the gas tank, from an average before the problem started of 9L/100KM to the last fill up today at 10.4L/100KM with the same mix of driving (approx 60km short trip city and 200km highway per week)
Only other thing I've noticed is that the exhaust note seems "boomier" until the car warms up (5 - 10 minutes of driving) and the occasional crappy idle (The RPM's are at the normal range at a stop but occasionally the engine idle isn't smooth at all, not the the point of stalling, but I can feel the vibrations)
Any ideas?
Threads: 347
6
DPF..........Welcome to the world of Ford. Just replaced mine on the truck after I blew a cell and the gas mileage went from shite to great and it was running rough beforehand.
Threads: 173
meford4u,Nov 27 2005, 02:35 AM Wrote:DPF..........Welcome to the world of Ford. Just replaced mine on the truck after I blew a cell and the gas mileage went from shite to great and it was running rough beforehand.
[right][snapback]157856[/snapback][/right]
Gah... better bring it in Monday then <_< But it isn't showing a CEL at this point so I'm surprised that the DPF has gone south silently like this :blink:
Threads: 238
Damn...all I saw was 'POT' in the title of this thread!!
Threads: 52
Threads: 529
Wow... that sucks. Hope you get it straightened out, Daniel.
Not even telling you what I did for mileage this weekend then... <_<
Threads: 173
Update:
Got the car back from Ford - No Fault Present (of course it is 13C today too <_< )
However they did leave a lovely printout in the car of what I'm assuming is a service note that says some '05's may have stumbling/surging issues due to the need to heat the cat during cold weather/using winter grade fuel. Without any diagnostic codes no fix should be attempted :rolleyes:
So IOW driving the car in the winter over short distances (less than 3km to work one way) I should just bend over and kiss my ass buh bye? <_<
Irony #1 - When I took the car in they assumed it was because I was notified for the recall work (The rear door latches) I was like BWAH? I never got any notice...
Irony #2 - I come home tonight and guess what's in my mailbox? Yup, recall notice :rofl:
Threads: 411
NefCanuck,Nov 28 2005, 09:03 PM Wrote:However they did leave a lovely printout in the car of what I'm assuming is a service note that says some '05's may have stumbling/surging issues due to the need to heat the cat during cold weather/using winter grade fuel. Without any diagnostic codes no fix should be attempted :rolleyes:
[right][snapback]158167[/snapback][/right]
oh well for built for life in canada. :lol:
Threads: 529
I wonder if:
- it's only a Duratec 2.0L problem?
- does the Duratec 2.3L do EXACTLY the same thing?
- does 91+ octane fuel make it go away?
Threads: 313
21
That's just great - no ambiquity there.
WTF does the note mean? Doesn't the cat heat up by design - more specifically, by Ford's design? What control do you have over how fast the cat heats, unless their note is some sort of code for "let it idle for 10 minutes before driving" - but then again, wouldn't they just come out and say that?
As for winter gas (and I could be mistaken here) but I thought there was some sort of law that forced fuel companies to only serve winter gas between certain dates.
I think what the note is really saying is "too bad pal, live with it."
Threads: 96
letting the car heat up first sound like its exactly what there saying... if your just makeing short trips .. 5 mins or less .. then obviously the car isnt really gonna have time to get up to temperature.
and the cat needs to be nice and hot inorder for it to properly work .. that's how some shops used to "force" cars to fail emissions test .. they'ed aim that massive fan towards the ground, forcing cool air under the car and onto the cat, thus making it seem like the cat was failing and then telling you it needs to be replaced.
so .. just hit the automatic starter 5 mins b4 you go outside in the morning, and your good to go
Threads: 173
schade,Nov 30 2005, 12:41 AM Wrote:letting the car heat up first sound like its exactly what there saying... if your just makeing short trips .. 5 mins or less .. then obviously the car isnt really gonna have time to get up to temperature.
[right][snapback]158478[/snapback][/right]
Except I'm parking in an underground garage, both at home & at work and the temp never drops below 5C or so :(
As the temps begin dropping this week, I'll see if the problem resurfaces, if it does I'll let them keep the car overnight so they can diagnose it.
Threads: 529
Daniel,
Can you log all your mileage / kilometerage and rate that against actual fuel being used? if it's stupidly low, you can go after Ford about it because the car's obviously not running right.
Just record the date, fuel purchased in liters, and how far you drove before you filled. Keeping a log when you suspect something is never a bad thing... it just shows you're thinking at the right level.
Threads: 173
NOS2Go4Me,Nov 30 2005, 01:23 PM Wrote:Daniel,
[right][snapback]158562[/snapback][/right]
Been doing that for the last three months now, it's only been the last two fillups where the mileage went south (when things went cold temperature wise)
Threads: 43
Could be bad gas.
But from your first post, it sounds like you have an exhaust leak before the cat.
Threads: 173
Fingers,Nov 30 2005, 07:22 PM Wrote:Could be bad gas.
[right][snapback]158635[/snapback][/right]
That's what I was thinking, but why would the booming exhaust note go away when the outside temperature is warmer? Ten degree swing in the ambient air temp can make that much of a difference? :blink: (and if it is the exhaust, would this be a warranty item under the 3/60k warranty) or is this the expensive excuse I need to invest in an MBRP exhaust? :P
