Microwave Snowplows?
Brave New Highway
Coming soon: The microwavable road?
12/1 - About three years ago, engineer David Hopstock was mulling ways to boost the sagging fortunes of Minnesota's Iron Range. The Roseville-based consultant had no ideas about how to improve the market for taconite pellets, the range's main export. But that wasn't what interested him. He was looking for potential uses for taconite tailings, the waste material left behind in staggering quantities by taconite production.
Hopstock, who has a Ph.D. in metallurgical engineering, knew that the tailings contained a high percentage of a mineral called magnetite. From his days working at the U.S. Bureau of Mines, he also recalled that magnetite is an exceptionally good absorber of microwave radiation. That's what triggered his eureka moment. If the tailings were mixed with asphalt, Hopstock speculates, a powerful microwave generator might then be applied to the road surface. That could have a handful of practical applications. In cold, icy weather, for instance, a microwave-emitting device hitched to a plow truck could be used to deice the road, thereby eliminating the need for salt or other corrosive and environmentally hazardous chemical treatments. Even if it proved impractical or too expensive for large stretches of road, he says, it might be very useful for bridge decks and runways.
Because taconite tailings are easily heated with a microwave, Hopstock theorizes, a pothole patch made with tailings would work much better than the current "throw and go" pothole repair technique. And in any weather, Hopstock thinks, the paving of new roads might be vastly improved through the use of a microwave, since it is critical that asphalt temperatures be maintained within certain parameters to set properly.
Will it work? Hopstock has yet to conduct a field trial, because he hasn't been able to get adequate funding. But his small-scale experiments--kitchen scale, in fact--have yielded some promising results. In one such trial, Hopstock filled a Styrofoam cup with magnetite-rich epoxy, then covered it with water and put it in a freezer. After a hard layer of ice formed over the epoxy, Hopstock placed the container in a standard-sized microwave oven and zapped it. Within a matter of seconds, he noted, the epoxy had absorbed enough heat that the ice ceased to adhere to the surface. "I think that demonstrated, well, that it's not a totally wacky idea," Hopstock says with a laugh.
With such results in hand, dramatized by a detailed Power Point presentation, Hopstock and research colleague Larry Zanko floated their proposed technology at a seminar hosted by the University of Minnesota's Center for Transportation Studies. Erland Lukanen, the director of the Pavement Research Institute at the U, says he was intrigued by the potential, especially the pothole patching application. The chief issue, Lukanen says, is economic. It's not just an issue of equipping highway trucks with giant microwaves. Because bulk materials are expensive to transport, he explains, most aggregate comes from local quarries. For any projects outside the Iron Range, that raises the question: Would any city or state agency be willing to pay the extra freight to haul taconite tailings from northeast Minnesota? Probably not, in the near future. But as the Twin Cities metro area continues to grow, Lukanen notes, it has become more difficult to develop new quarries, which may mean the economic equation will shift.
Hopstock and Zanko's proposal for the tailings is not without critics. At the Center for Transportation Studies seminar, two old lions of Minnesota's environmental movement--retired federal judge Miles Lord and former Minnesota Pollution Control Agency chief Grant Merritt--raised objections based on the possible health risks. Both Lord and Merritt are concerned because some taconite tailings are known to contain asbestos and asbestos-like fibers. Those fibers, they fear, may be related to the elevated levels of a rare but deadly cancer called mesothelioma on the Iron Range.
From 1988 to 1999, according to a 2003 Minnesota Department of Health study, there were 81 identified cases of mesothelioma among residents of northeastern Minnesota, nearly double the expected rate. For that reason alone, Merritt contends, any use of taconite tailings in highways should be subjected to a full environmental review.
Lord, who issued the landmark 1974 ruling that prohibited the dumping of taconite tailings into Lake Superior, takes a more conspiratorial view. The use of taconite tailings on highways, Lord contends, represents "a deliberate attempt by the taconite industry and its owners, 'Big Steel,' to spread deadly particles on Minnesota highways, thereby making it difficult, if not impossible, to pinpoint the cause of cancer deaths on the Iron Range because cancer will occur throughout the state of Minnesota."
In Zanko's view, such claims are both needlessly inflammatory and "pretty much a red herring." He points out that the Department of Health study concluded that higher levels of mesothelioma on the Range were most likely the result of exposure to commercial asbestos, not taconite dust. A fellow at the University of Minnesota-Duluth's Natural Resources Research Institute, Zanko further notes that tailings have been used in road construction in northeast Minnesota for decades, without apparent ill effect. (And, he adds, highway engineers like using the tailings because they are very durable and have superior friction characteristics).
Zanko further points out that there is no proposal to use tailings from the eastern part of the Iron Range, where the asbestos-like fibers have been identified in taconite. The geology of five pits from the western part of the Range, he says, is markedly different. Examination of the tailings from that region has not revealed any significant levels of asbestos-like fibers. None of this satisfies Miles Lord. He counters that the MDH taconite dust study was sharply criticized by some scientists for its methodology and conclusions. Additionally, Lord notes, at least one EPA scientist has gone on record stating that the testing of the western range for asbestos has been inadequate.
Beyond any environmental concerns, it remains an open question whether Hopstock and Zanko's dream of microwavable roads will come to fruition. The pair is hoping to receive as much as $1.6 million to fund a three-year research project, but the money has yet to come through. Says Hopstock: "This has all been done on a shoestring, so until we get more funding to do a field test, we won't be able to demonstrate feasibility."
From City Pages Online News of the Twin Cities
Ok new rule.
if you have a long post that involves reading you must include cliff notes....
no one enjoys reading. kthxbye
nass,Dec 1 2005, 10:55 AM Wrote:Ok new rule.
[right][snapback]158777[/snapback][/right]
[Image: MICROVAVE.jpg]
[Image: REDNECK%20SNOWPLOW.jpg]
[Image: road.jpg]
:rolleyes:
newb
:lol:
Cool.... Love the snowplow! LOL
One of my customers hates snow on his driveway so he had radiant heat installed though out the entire driveway. It stays warm all the time, warm to the touch so no slow ever builds up on it. Makes for a hell of an icy road though as all the melted snow flows off onto the road and sidewalk.
I have a few cars.
One for my dog.
One that has no roof.
Flofocus,Dec 1 2005, 11:13 AM Wrote:^^
:lol:
[right][snapback]158786[/snapback][/right]
I guess I now know what happened to my old Subaru Loyale 4x4?
[Image: 05-30-03tcs30-17.jpg]
Flofocus,Dec 1 2005, 12:13 PM Wrote:^^
:lol:
x5!!!!
Euro Ford Fan,Dec 1 2005, 11:28 AM Wrote:Cool.... Love the snowplow! LOL
[right][snapback]158788[/snapback][/right]
must be nice!
I always wondered why they don't build heated highways. I don't think it would be too difficult or exspensive. Just cycle water.
ANTHONYD,Dec 1 2005, 12:00 PM Wrote:I always wondered why they don't build heated highways. I don't think it would be too difficult or exspensive. Just cycle water.
[right][snapback]158798[/snapback][/right]
Do you mean like the "deep water cooling project" downtown but reversed?
Could possibly work but you'd need antifreeze in the land side lines, a pumping station like a John Street and then run the lines out into the Lake a couple miles which would be your heat exchanger. That way you could do something like the Gardiner but the cost, YIKES!
imagine what you could do with lasers...
Cost yes.
But think of the money saved in trucks plowing etc....
Not to mentions the billions of dollars wasted on patch mixture every year and the 12 guys at time-and-a-half filling them.
they already have that in iceland.. that only really works in area where there is volcanic activity beneath it.. you simply tap into it and the steam the escapes gets collected into pipes then warms the road type deal. TO do that here in Canada would be very expensive since we're not really on a hot bed of volcanic activity.
[Image: road.jpg]
:rolleyes:
newb
[right][snapback]158783[/snapback][/right]
thanks for complying.
Lasers? What about the sharks? Don't they have job security? They could patrol the pipes for interlopers, and the lasers would heat the water to keep the road clear.
Problem solved B)
NOS2Go4Me,Dec 1 2005, 01:01 PM Wrote:Lasers? What about the sharks? Don't they have job security? They could patrol the pipes for interlopers, and the lasers would heat the water to keep the road clear.
Problem solved B)
[right][snapback]158820[/snapback][/right]
Until the giant car eating lobster showed up.
Even if their project of microwavable roads dosen't see the light, the use of their taconite pellets as replacement in the making of asphalt is a good thing.
I don't know exactly how many million of metric tons of crushed stone is used each year but I know for sure that at this rate we'll be in need of new recycled materials for our roads.
got gas?
The neighbours next to my parents have the same idea in their driveway, but electric. It was installed by the developer in the 1970's. They used to ask me to come over all the time and shovel the driveway ( they bought the house in mid 80's) I would go over and flip the switch after they went to work and collect $20.
Now you know where I got it from.
ANTHONYD,Dec 1 2005, 01:50 PM Wrote:Cost yes.
[right][snapback]158815[/snapback][/right]
Other problem Anthony is that those systems (Be they gridlines, waterlines, etc.) break down over time and they can't be "maintained" to prevent such breakdowns. It either works or it doesn't.
That's the situation at my condo right now, the heated ramp isn't working so now they're using salt until it can be repaired and a cheap fix this isn't <_<
What's to stop it all from freezing again afterwards?
I mean, you run this microwave, heat it all up, melt more of it, than it all freezes as a sheet of ice immediately afterwards (cuz it'd be a fairly thin layer). So now we have skating rinks instead of salt and dirt/sand.
I think it's not gonna work in the real world.
I mean there's supposed to be drains and everything, but more than likely they're be covered with snow, so the water will have no where to go and just freeze.
Am I missing something? also yes I didn't read TFA.
Silver '05 Saabaru 9-2X Aero
