Duratec Engine Cover
#21
NefCanuck,Aug 14 2006, 11:41 PM Wrote:How is that cover working out for you?  Any issues you've noticed?
[right][snapback]202411[/snapback][/right]
The cover is for the most part good, but it does get DANG hot. But it does sit up a bit from the engine, pretty close to the hood, so it does get airflow under it, so I can't really see that it's any hotter than the hood alone. No heat issues so far.
A couple of issues I had was with the mounting, I used the two rear rocker studs to mount it in the back, occasionally it popped off, no damage just a rattle; but I've used a tiny bit of silicone adhesive on each stud which solved that problem. The only other issue was the plastic I used for the edging. Because it comes in a strip, I have to find a better way of getting joining the two ends, as one end came loose and fried on the exhaust manifold, so I took it off for now.
bump... still in the testing ?
Ford Focus SES ZX5
TEAM DURATEC # 99
  A Little Useless Info About The Duratec Engine. Scorcher000 2 7,380 08-07-2008, 02:30 PM
Last Post: Dimitri
