Deal Of The Day For Computer Guys
#21
I idle @ 30-32C, full load @ 40-45C depending on ambient.
Custom plexi full tower case, Winchester 3200+ @ 2.4GHz, 1.575 vCore, Venus 12HSF and OCZ Ultra 5+ thermal grease.
For you guys with Venice core chips (S939 Rev. E), make sure it's getting 1.4V and not 1.5V to the core. The same was true of the Winchesters (rev. D) before the BIOS updates were issued by each mobo manufacturer.
The BIOS wouldn't understand the revision of the CPU in the microcode (CPUID) and would erroneously assume it was an earlier 1.5v part.
Scooba - I had to run at work before I could answer earlier. What thermal grease / thermal interface material is on your HSF?
My rig (not the greatest shot):
[Image: newdesk.jpg]
My board fed my CPU 1.3v instead of the 1.4v. Ran perfectly stable so I was like meh, even got it to overclock up to 2.25 GHz like that, that's when I noticed actually cuz i went in to adjust. I think I'm running stock voltage and 2.4 GHz. Yay!
oh, and that new Asus board with the like 8-phase power looks sweet!
Silver '05 Saabaru 9-2X Aero
hmmm, so many decisions..
Looking at the Zalman 7700, 9500 or the thermalright Xp-120 or XP90c
which would be better for overclocking?
05 Altima SE-R
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
IMHO, if you can't OC on the Venus 12 with good thermal grease (AS5/OCZ U5+) then you probably have bigger issues than the heatsink.
No offense of course. I'd stick with Thermalright over the Zalman stuff. They're ok (Zalman) but their quality seems to be lacking at times. Thermalright alwasy seems to knock it out of the park. I'd go XP120 if that's the road you want, but you'll need to check for clearanaces around the socket to accomodate something of that size.
I can overclock on the venus 12. no problem... for the brief 2 weeks i had the 3700+ San diego... i was easily able to get it to 2.5ghz..
my problem is with all the added heat of the geforce my cases ambient temp is always hovering around 35-40 degrees... my room is pretty warm itself.
I just want to be able to have the cpu running safley at 2.8... under 50 degrees with a low fan speed so i can sleep at night.
The venus 12 is just too loud at full fan speed.
05 Altima SE-R
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
scoobasteve,Nov 30 2005, 01:30 PM Wrote:hmmm, so many decisions..
[right][snapback]158563[/snapback][/right]
Go with an XP 90c and one of these babys:
Vantec Tornado 92mm
Best air cooling solution ever, and 56.4db of pure deafening sound. :lol:
Also, I'm using Arctic silver 5...
with the fan on at about 3000 rpm now it idles at 48. with the fan on full it will go down to 43 degrees.
Eventually i want to go watercooled. if only my case had more room i'd go with an Aquagate mini for now. or a bigwater SE.
05 Altima SE-R
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
The San Diego is a 2.2GHz part. You're extending it 600MHz beyond stock spec, which is quite the feat for any overclocker, especially on air.
I run my Venus 12 @ 4600 RPM (as reported by SpeedFan) and the same for Sara's venice 3500+ (2.2GHz @ 2.53GHz) and it's noticeable but not THAT loud. It could also be attributed in part to the acoustical properties of the case.
With that said, moving to a larger diameter fan with a lower rotational speed will almost certainly rectify the problem. My real concern would be the quality of the copper base for the heatsink, number of heatpipes (if any), and whether it's a push/pull dual-fan design or a single fan.
Duals are my favourite. Let me find a link to a personal fave cooler in that config.
EDIT - just read your other reply. What processor, speed and voltage are you running?
There's no way you should be idling that hot. I idled that hot with a stock Winchester (hotter than the Venice Rev. E cores) and the stock PIB aluminum heatsink and 60mm fan, OCZ Ultra 5+.
Vantec Tornado 92mm
[right][snapback]158567[/snapback][/right]
Deafening sound makes baby jesus cry....
if i didnt care about sound i'd be rocking this
118 CFM of FURY!
05 Altima SE-R
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
scoobasteve,Nov 30 2005, 01:47 PM Wrote:Also, I'm using Arctic silver 5...
[right][snapback]158568[/snapback][/right]
Pfft. Watercooling is for pussies.
sorry adam, i should have clarified..
I had the 3700+ Last week, i actually sold that. (had it running at 2.5 stable) ran nice and cool too... 45 degrees under load.
Now i'm using an FX55 Clawhammer... i want to get that at fx57 speeds
System Specs
Case - Thermaltake Xaser III - 1000a (7x 80mm fans)
Asus A8N-SLI Deluxe
AMD Athlon 64 FX-55 Clawhammer
2gb OCZ Platinum PC3200
BFG Geforce 7800gtx OC
SB audigy Platinum Pro
OCZ Powerstream 600w
2x 250gb WD SATAII
1x 250gb Maxtor SATA
LG 16xDVDRW
LG 16x DVD Rom
Sony 52x CDRW
05 Altima SE-R
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
I thought I saw a dual config for this, but it's sweet either way:
http://www.thermaltake.com/coolers/4in1hea...er/cl-p0071.htm
Water-cooling is great for quiet cooling, but no better than air for extreme cooling performance.
Oscar, I'll come up there and slap you with the BANNED IP stick.
No Internet for you!
What do you guys think of the aquagate mini? It will take a bit of extra work to install it. but it may be worth it.
It will be a bit harder to install due to the stupid tool free thermaltake design. all the fans snap into place. so i'll have to remove the plastic and fab up a new bracket.
05 Altima SE-R
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
Well i did some more research on the Aquagate. and i'll be staying as far away from that as possible... cracked waterblocks. 1-2 degrees temprature difference between air cooling... bleh
05 Altima SE-R
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
I can't recall if this was mentioned. But organized the wires in your case can also have a great impact. My Friend finally did it to his case, got him 5-6C.
mine are pretty organized... i just gotta add some more wire loom and i'll be set...
wow.. 7800gtx's give out massive amounts of heat...
it could heat my house..
05 Altima SE-R
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
Steve, I think pretty much any all copper / copper pipe / aluminum fin cooler will work for you with either a 80mm high CFM fan or a bigger and lower rotational speed fan with the same CFM or better.
The Clawhammer is a 130nm part, running at a higher voltage. It's also an earlier revision so it doesn't have the latest design advances in the chip architecture... thus leading it to run hotter again.
I'd say you'd need to see how the actual airflow is in the case... with that many fans, your ambient (best judged by your HDD temperature minus 5-6C at idle) temperature should be aiding the heatsink to the point that this isn't an issue, even with a CG-stepping 130nm FX-55.
Otherwise, post up what CPU-Z reports your model and revision as.
Thanks
Adam
[Image: th_Stats.jpg]
That's at idle. Click the image.
Nice numbers... OCZ platinum is fantastic... the only thing is the 2gb dual channel kit runs as 2-3-2-5...
If i try to run it at 2-2-2-5 its unstable... bleh.
and at 2-3-2-5 - at 400mhz... i can only pull 5100 mb/s
I'm going to go with the zalman. i figure i'll start with a more efficent heatsink and possibly do a fan mod to it.
With my fan on full the cpu is only 4 degrees above case temp...
which is 15 degrees above ambient. I think i need a bigger case because that geforce is heating it up something fierce
05 Altima SE-R
05 300C 5.7: Sold
99 Civic SIR: Sold
03 Focus SVT: Sold
01 Focus ZX3: Sold
[Image: richdiesslin_geeks.gif]
***want to buy***
MBRP................ check
SCT Xcal2 ........ check
VF mounts
Adj. Dampers ... check
Meford's Mom.... sale pending
  Computer Guys I Need Help Plz habmann 12 4,188 03-22-2007, 02:03 PM
Last Post: habmann
  For You Computer Guys smith21 7 2,754 07-22-2005, 03:44 AM
Last Post: ANTHONYD
