Should I Take Off..?
#21
what if i leave egr system in place but disable it by tune??
will i still have problem with emission test??
konafocuswrc,Jun 26 2009, 11:44 AM Wrote:what if i leave egr system in place but disable it by tune??
[right][snapback]290187[/snapback][/right]
The answer is likely yes. A non functioning EGR valve will cause the exhaust fumes to have too much of the "bad stuff" (NOx I think, but don't quote me)
the EGR system is designed to reduce NOx emissions.
You can disable it to run your turbo and re-enable it to do your e-tests as well.
But the fact is, you don't have to disable it to run a turbo -- it just means you have to tune for it as it results in slightly higher IATs and cylinder temps.
ah~good to know
learn something new everyday
gotta stop being cheap, going to order dpfe and see if it fixes, then egr valve..
