What's Your Screen Resolution?
#21
Focus man, Focus.,Nov 28 2008, 08:47 PM Wrote:1024 X 768 if I go any bigger everything gets so tiny.  I have a 20" LG Flatron monitor.
[right][snapback]277365[/snapback][/right]
How do I increase my resolution without making my icons so tiny?
2008 Taurus X to be modded.
Still The Weakest LinkBlush
[right][snapback]277730[/snapback][/right]
First and easiest trick is to right click on your desktop, hit 'Properties' then the 'Appearance' tab and then bump up your Font size. If that doesn't do it for you, then you need the following paragraph...
What you need to do is right click on the desktop, click on 'Properties' then 'Settings' and hit the 'Advanced' button, then make sure you're on the 'General' tab and then change the DPI setting to 'Large' for a start, if that's still to small try the 'Custom' setting.
[right][snapback]277755[/snapback][/right]
I'd also like to mention normally running a LCD outside it's native resolution (for a 20" it's normally 1680x1050) can make things appear blurry/bad looking. The LCD panel itself inside the monitor performs the best at it's native res. Sharpness everything looks better.
2005 Liquid Grey ZX3 RIP
Back from the dead. I forgot about this but I am going to play around with it tonight.
1280x800 which is about exactly 16x9 High Definition aspect ratio for wide screen hd playback on my work RSO Laptop..
on my desktop its only 4x3 ratio 1024x768 Standard Definition
My other ride is your Mom
Well I am up to 1280 X 1024. This is going to take some getting use to. The resolution is much better, colour is better and the images are crisper. But the text is a little bit smaller now. But so far I like it. :)
  What's Your New Year's Resolution? darkpuppet 15 5,253 01-05-2006, 03:18 AM
Last Post: Euro Ford Fan
