Garage Sale - Check It Out
#21
BUMP - with followup and new information.
EBAY PROJECTORS
Confirmed - all four headlights work - awaiting dibs confirmation from AckermaN
REAR SWAY BAR
Confirmed - this is a 21 mm bar just like the SVT - awaiting dibs confirmation from Canada ST
TUNER LUGS
This pack actually comes with 20 nuts (not the 16 I posted) - so four of them are unused - Hardkore has dibs - are you coming out Monday night?
HELLA PROJECTORS
** REDUCED PRICE - NOW JUST 150 **
Anton - did you notice the colour of these puppies? LOL
I'll take #8 end links if they fall thru...
[Image: 160510.png]
[Image: 160577.png]
WuNgUnSVT,Oct 3 2008, 12:55 PM Wrote:I'll take #8 end links if they fall thru...
[right][snapback]273804[/snapback][/right]
2nd dibs - I'll let you know.
TTT - updated info
Waiting for responses to PMs ... dibs are about to expire.
Hi Ken. pm's not working right now for some reason ...
Do you have any suggestions on how I could use the FF50 lights to replace the factory fogs. I'm very interested in these, but don't want this to become an all consuming project with new wire harnesses etc
Otherwise I'll purchase the 4 x FL400s filters @ $10
My wagon thinks it's faster than your wagon ...
grahama,Dec 29 2008, 05:06 PM Wrote:Hi Ken. pm's not working right now for some reason  ...
[right][snapback]278880[/snapback][/right]
Yeah, PM systems been down for a while ... the FF50s will replace the fogs in a 00-04 without too much trouble (different shape of course so you'd have to use the brackets that come with the Hellas) but on 05+ you'd have to remove the black plastic housing surrounding the fogs - not a lot of work, but that leave's a pretty big space. In any event they should not be considered direct replacements.
If you need better photo's of the brackets it's easy for me to do ... send me an email.
ken_ken52 "at" hotmail "dot" com
Cheers ... Ken.
#11, what difference would i see when using from 5w-30 to 5w-50??
konafocuswrc,Dec 30 2008, 08:50 PM Wrote:#11, what difference would i see when using from 5w-30 to 5w-50??
[right][snapback]278918[/snapback][/right]
I'm no oil expert, but AFAIK the "5W" rating assures you of the low temperature rating (below 0 degrees Fahrenheit) which is important for protecting the engine at low temps, ie: at start up.
In terms of the high temp rating the "30" rated oil would have quite a bit less viscosity at 100 degrees Centigrade than does the "50" ... based on my understanding the 50 would offer somewhat greater protection at the cost of performance and economy.
Technically the difference between SAE 30 and 50 is expressed as follows:
30 - between 9.3 and 12.5 cSt @ 100C
50 - between 16.3 and 21.9 cSt @ 100C
Hope this helps.
i ll let you know when i get paid
Thanks for the Swaybar Ken!
Canadian ST,Feb 14 2009, 04:14 PM Wrote:Thanks for the Swaybar Ken!
[right][snapback]281115[/snapback][/right]
You're very welcome - it was good to meet you and thanks for the free bump ... new prices and other updates (including FREE STUFF!!), please look at the first post for details.
And oh yeah, the push to fit two cars in my very cluttered garage is off (drunkinmonkey's got nothing on me) - LOL too close to spring to worry about it now.
I will take a 4 pack of Zetec oil filters if you still have them. Let me know if you still have any.
Thanks.
2008 Taurus X to be modded.
Still The Weakest LinkBlush
Focus man, Focus.,Feb 15 2009, 10:07 AM Wrote:I will take a 4 pack of Zetec oil filters if you still have them.  Let me know if you still have any.
Thanks.
[right][snapback]281142[/snapback][/right]
Sure (what, no oil? LOL) ... can I drop them off at your work next week - I'm going to be down that way on Tuesday.
Thanks.
Ditto?
2013 performance blue ST
TEAM P.I.T.A.
Thanks.
Ditto?
[right][snapback]281175[/snapback][/right]
I may have only 2 or 3 left after giving Kev his 4 - - if so you're welcome to them at 2.50 ea.
BUMP WITH PRICE REDUCTIONS AND MORE FREE STUFF ADDED
3) Hella FF50 Driving Light Kit – NEW – (cost $100) – 35.00
4) Complete 07 wagon suspension – springs have just 4k, dampers have 40k – will fit all Focus wagons – 8-pcs - 140.00 ** REDUCED TO JUST $60 FOR ALL FOUR CORNERS !! **
9) 05-07 Focus grill – chrome surround on silver insert – Virtually new (Take-off) – 35.00 ** REDUCED TO JUST 20.00 !! **
14) 4-Motorcraft SP448 spark plugs – Duratec - NEW (compare at 82.00) – 41.00 **REDUCED TO JUST 30.00 FOR THE SET **
15) 4-Motorcraft SP478 spark plugs – Zetec - NEW (compare at 52.00) - 26.00 **REDUCED TO JUST 20.00 FOR THE SET **
NOW WITH MORE FREE STUFF ADDED
2-OEM Ford FRONT rotors 05+ - 20k, lots of meat left – I replaced them with Brembo, they ran true when I had them on - 20.00** FREE TO GOOD HOME (includes pads) - COME PICK EM UP**
Complete wagon OE Duratec exhaust - from 07 very low km - was cut into 3 pcs for removal prior to MBRP install **FREE TO GOOD HOME - PICK UP ONLY**
Wagon retractable rear compartment cover - silver - perfect condition **FREE TO GOOD HOME - PICK UP ONLY**
Thanks.
Ditto?
[right][snapback]281180[/snapback][/right]
I'll take whatever you have left, but since I just changed my filter last week I can wait until the warmer weather meets to pick up the filters. (unless you're passing by Maple or Thornhill)
TEAM P.I.T.A.
Will the 07 suspension bits fit a '00?
chromehorse,Feb 16 2009, 07:12 PM Wrote:Will the 07 suspension bits fit a '00?
[right][snapback]281202[/snapback][/right]
Yes - the fronts will fit any Focus built (00-04 you have to keep the struts and springs together) and because they are wagon spec, they would be considered heavy duty for hatch or sedan.
The rears will fit wagon only.
Someone with a facelift Focus should buy that grill. Its a total steal! Cut it up, mod it, rice it out just for fun. Who knows what it will turn out like. It maybe cool just to see what you come up with.
  Focus garage sale! MikkelRS 3 2,465 01-21-2016, 11:31 PM
Last Post: MikkelRS
  Garage sale thread. castone 4 3,530 01-11-2012, 02:42 AM
Last Post: JMCustoms
  Movember Garage Sale hardk0re 15 7,722 01-08-2012, 01:55 PM
Last Post: hardk0re
  Garage Sale Part 1 hardk0re 10 6,044 06-28-2010, 04:49 AM
Last Post: hardk0re
  Garage Sale hardk0re 12 5,963 02-04-2010, 11:18 AM
Last Post: 2009SEL
  Final Garage Sale Blackzx3 14 8,620 05-21-2008, 03:13 AM
Last Post: BananaClipper
  Garage Sale ! Mike 46 21,100 05-07-2008, 01:41 PM
Last Post: silvermist
