05-16-2012, 03:50 AM
wrc rally replica build thread
05-16-2012, 04:07 AM
(05-16-2012, 03:50 AM)ANTHONYD Wrote:(05-16-2012, 01:23 AM)buzz2.0 Wrote: wow engine bay looks nice white...probably wont stay white long....but its lookin good...keep it up, it should be on the road soon..... Yeah but only 'cause you're not normal.
2003 Focus ZX5 infra-red Track Rat - R*I*P 2003 ZX5 CD Silver Track Rat - retired, but still in the driveway New track rat: 2000 ZX3, Atlantic Blue * JRSC with lots more to come * New Zetec crate motor - NFG - thanks Topspeed *
05-17-2012, 08:56 AM
![]() ![]() ![]() ![]() ![]() ![]() BLACKBOX(DASHCAM) | LED | HID | REMOTE STARTER + SECURITY | 12 VOLT ACCESSORIES | CAR ENTERTAINMENT | PERFORMANCE UPGRADE | MAINTENANCE REPAIR
![]() info@motormaniac.ca | 905.508.3737 If you are calling after hours, please leave a pm or detailed voice mail and we will get back to you as soon as possible.
05-17-2012, 01:09 PM
You are going to have soo much fun with that little toy. Looking good. Keep it up.
05-18-2012, 08:33 AM
man I love those wheels.
05-18-2012, 10:06 PM
nice! whens the rally??? lol, once you have it road worthy we should go up north, find some dirt roads and test it out!!
2000 Black zx3-daily driver> Stealth bomber custom "bigman" turbo, all Black everything, SVT blue interior, SVT suspension, Magnaflow exhaust, AEM gauges 2000 Yellow ZX3...stock with MRBP exhaust... 1979 Mercury Capri 5.0 swap (work in progress) 2002 focus SE-wrecked/scraped/parted out RIP 1993 Vw Passat 1.9L tdi...das diesel sipper sold parted RIP 1993 mazda B2600 4x4 POS, parted, rusted to pieces 1990 Toyota 4runner 4x4 mud beast
05-20-2012, 10:51 AM
![]() some more wiring to finish. ![]() ![]() BLACKBOX(DASHCAM) | LED | HID | REMOTE STARTER + SECURITY | 12 VOLT ACCESSORIES | CAR ENTERTAINMENT | PERFORMANCE UPGRADE | MAINTENANCE REPAIR
05-20-2012, 09:59 PM
(This post was last modified: 05-20-2012, 10:00 PM by MuskokaZX3.)
Soo close Leo!!!
• 07 ST 23D • MBRP 2.25 cat-back • cfm 67mm TB • K&n Typhoon • Massive poly dogbone insert • Massive BSD • FRPP Dynamic springs & struts • carbon fibre shift boot & brake boot • SVT HVAC controls • steeda short throw shifter • Tinted w/ brow • SOON TO BE BOOSTED •
05-21-2012, 01:46 PM
(This post was last modified: 05-21-2012, 01:46 PM by konafocuswrc.)
still need to do some gauge wiring, taillight wiring, power steering fluid change, mtx fluid change, engine oil and get 91 octane in jerry can from gas station.
possibly, i will try to butcher wiring to have drl to come on high beam sides, not on low beams. wish me luck. BLACKBOX(DASHCAM) | LED | HID | REMOTE STARTER + SECURITY | 12 VOLT ACCESSORIES | CAR ENTERTAINMENT | PERFORMANCE UPGRADE | MAINTENANCE REPAIR
05-25-2012, 08:10 AM
everything is good and cranks but i am not hearing fuel pump whining..
checked fuel fuse and it gets power, relay clicks when key is on. at first i was getting p1233 which is FPDM disable/ offline. Possible causes: Inertia fuel shutoff (IFS) switch needs to be reset. Open FPDM ground circuit Open circuit to FPDM PWR RLY Open FPDM PWR circuit Open or shorted FPM circuit (engine should start). Damaged IFS switch. Damaged FPDM PWR RLY checked inertia switch and it was in, not popped out, i am not sure if it stays in or out. and i might switch high beam relay to this fuel relay to see if it fixes problem. BLACKBOX(DASHCAM) | LED | HID | REMOTE STARTER + SECURITY | 12 VOLT ACCESSORIES | CAR ENTERTAINMENT | PERFORMANCE UPGRADE | MAINTENANCE REPAIR
05-26-2012, 01:18 AM
Check all your grounds to the wiring to the fuel pump. I had the same code and just turned out be a bad ground right by the safety ennertia switch
...because RACECAR! haha
05-26-2012, 10:26 AM
found problem.
Diode #1, everything works now ![]() BLACKBOX(DASHCAM) | LED | HID | REMOTE STARTER + SECURITY | 12 VOLT ACCESSORIES | CAR ENTERTAINMENT | PERFORMANCE UPGRADE | MAINTENANCE REPAIR
05-26-2012, 12:14 PM
Sweet Leo... Running by the end of the weekend??
05-26-2012, 12:29 PM
(This post was last modified: 05-26-2012, 12:30 PM by konafocuswrc.)
not really..water pump housing to block and thermostat housing to block has some minor coolant leaks.
and i used diode #2 in diode #1 slot, so missing diode. and local ford dealers has nothing in stock. they will have by tomorrow, i hope. BLACKBOX(DASHCAM) | LED | HID | REMOTE STARTER + SECURITY | 12 VOLT ACCESSORIES | CAR ENTERTAINMENT | PERFORMANCE UPGRADE | MAINTENANCE REPAIR
05-26-2012, 09:10 PM
that's an amazing Focus WRC
05-28-2012, 11:49 PM
i can t wait to see this thing done, this is going to be one crazy focus!
05-29-2012, 05:05 AM
Focusmanfocus must have some of these diodes.....
05-29-2012, 08:02 AM
(This post was last modified: 05-29-2012, 08:14 AM by konafocuswrc.)
car is already up and running strong at 5psi.
i am going to up the boost 11psi and send datalog to randy sometimes this week. look what my friend done to my car.. oil cooler............... ![]() BLACKBOX(DASHCAM) | LED | HID | REMOTE STARTER + SECURITY | 12 VOLT ACCESSORIES | CAR ENTERTAINMENT | PERFORMANCE UPGRADE | MAINTENANCE REPAIR
05-29-2012, 09:25 AM
Some friend. How did that happen?
2008 Taurus X to be modded. 2002 ZX5 parted out. Forever known as the "SLOCUS". 2010 Dyno #'s 102.96HP/105.84TQ 2011 Dyno #'s 111.44HP/115.17TQ Still The Weakest Link ![]() Dial 1-800-AUTO-PARTS for your local speed shop.
05-29-2012, 11:20 AM
looks like trying to get the tappered brass fitting to go all the way in ....
« Next Oldest | Next Newest »
My first build thread, 2000 ZX3 turned RS | MikkelRS | 59 | 32,885 |
07-16-2016, 02:56 PM Last Post: MikkelRS |
Few new parts, possible build thread? | jtdanks | 40 | 27,809 |
05-11-2013, 09:49 AM Last Post: jtdanks |
