Replacement Bulb For 02+ Euro Headlight?
I have 02+ Euro headlights and I just noticed that my passenger side low beam light is out. The bulb is separate from the high beams and right now when I turn the lights on, only the city (peanut bulb) lights up.
Can I get this bulb locally?
2013 performance blue ST
TEAM P.I.T.A.
it is either a H7 or H1 bulb and they are very common bulbs but a bit more expensive than your standard headlight bulbs. you should be able to get them at any autoparts store. if you pull out the bulb it will say right on it what it is. off the top of my head, i cannot remember which bulb it is.
if you got the headlights from me then i use standard Hella bulbs, i'd suggest buying the same if you are just buying one or buy a pair of another brand as they are often slightly different colours from brand to brand.
good luck!
I have the same headlights as you do ( St170's )
Low - H7
High - H1
if you have the 02+ fogs its H11
and yeah you can get these bulbs anywhere including ford if you want to pay more lol..... :lol:
  Focus Headlight Bulb Question Jmountney1 16 7,655 02-09-2011, 01:05 PM
Last Post: Aegeon
  Bulb For 02+ Euro Turn Signal? dBlast 5 2,599 09-10-2009, 11:25 PM
Last Post: Frost__2001
  Euro Headlight Harnest Chromey 5 2,430 12-08-2006, 11:03 AM
Last Post: mo_focus
  Hella Projector Bulb Replacement brucktown 7 2,931 02-24-2006, 10:47 AM
  Headlight Bulb Harness? ZX3guy2000 15 4,340 12-14-2005, 01:54 AM
Last Post: ZX3guy2000
