Wtb: Headlight Wiring Harness
My wiring harness is pooched. Noticed one of my headlights was out and when I swapped out the bulb and it was still out I took a closer look. The harness is broken and the wires frayed. Need a new one. Just one will do.
Need one that holds a 9003/H4 Bulb, preferably one from a Focus.
If you're going to a wreckers, please pick me up one. I won't be getting new headlights now for a while (if at all), so I need this to get me thru the winter :) Thanks.
2000 Black ZX3
I should be able to pull the wiring out of my wrecked ones. So I understand, the wiring that runs from the plug on the inside of the lamp, to the bulb. I'm pretty sure it has three prongs on it...
Raine,Oct 25 2005, 11:07 PM Wrote:My wiring harness is pooched. Noticed one of my headlights was out and when I swapped out the bulb and it was still out I took a closer look. The harness is broken and the wires frayed. Need a new one. Just one will do.
[right][snapback]151584[/snapback][/right]
If you fryied the socket make sure you have the right wattage bulb in there or it will happen again. 55/65 is max
Cheers
Alex
Been running 80w/80w for years, that's what buggered it in the first place. I really should invest in a heavy duty harness, but meh :P
2000 Black ZX3
  Wiring harness kc focus 2 3,060 09-03-2010, 09:27 PM
Last Post: kc focus
  Factory Headlight Harness (scrapyard ?) scoobasteve 7 3,074 01-23-2006, 03:06 AM
Last Post: Fingers
