Maybe A Repost?
Okay guys, how the FAWK...do you remove the headlight housing.. it quite obvious there are two screws on the top of it, but i can't seem to get it out ...is there a hidden bolt that i can't see????
thanks in advance
Mods so far:
Taken from exterior mods list for 2000-2004. Yours maybe different for '05, but should give you an idea of where to look.
"Remove headlight screws using 10mm socket. There are two on the top, one
near where the grill screw is (which is a screw/clip) and one under the headlight.
You will need to crawl under the car to reach the bottom one. The screw/clip can
be removed by unscrewing it and then gently pulling it up."
ya I had the same problem...there are 2 screws...one per housing, underneath the car. once those are gone the lights come right out.
