Wanna Hook Up My Tach
Has anyone done the "attaching of the signal wire from a tach to pin 48 on the ecu" mod yet? If so would you happen to have a pic of the ECU so I have a general idea where to attach this wire. I am pretty much ready to wire this bad boy up.
ThraxXx,Sep 13 2005, 08:10 AM Wrote:Has anyone done the "attaching of the signal wire from a tach to pin 48 on the ecu" mod yet?  If so would you happen to have a pic of the ECU so I have a general idea where to attach this wire.  I am pretty much ready to wire this bad boy up.
[right][snapback]141562[/snapback][/right]
I wrote a "Howto" over on FocusFanatics, if you have an '05 Duratec it's at the beginning of the thread (with pics), references to the earlier Foci ECUs (Pin 48) are near the bottom of the first page.
Installing a tach driver to the ECU/PCM
