09-01-2005, 11:25 AM
Some Focus owners may experience rear wheel bearing problems :lol:
You can buy just the bearing from Ford. Some other shops may try to sell you a complete drum assy. This is not necessary. The bearing costs about 60 bux. It comes with a new nut and snap ring.
First you have to get the wheel off. Remove the dust cover in the hub. You'll have to use a small flat screwdriver. You'll probably bend the lip on the cover. This is easily fixed with pliers before installation. Remove the nut holding the bearing/drum to the spindle using a 30mm socket. It is very tight. Once the drum is off gently pry out the dust ring on the inside of the bearing. Be careful not to bend it up as you have to reuse it. Remove the large snap ring inside the hub. Now this is where you'll need some not so average tools. Press the bearing out. You'll have to use a press for sure. Taking note of the way the bearing is installed. ( both sides are different on the bearing). Press the new bearing back in the same way, put the new snap ring in, gently tap the inner dust ring in and put the hub back on the spindle. Using the new nut torque the spindle to 173 ft/lb. replace dust cap and put the wheel back on.
Drive until the next wheel bearing failure.
I'll get the part number for the bearing and post it up here.
![[Image: 860doigiveadamn2yy.gif]](http://img451.imageshack.us/img451/8269/860doigiveadamn2yy.gif)
Prolly Is not a word
