Fuse And Relay Purposes
These allocations apply to the 2000-2004 Ford Focus. They also tentatively apply to the 05+ Focus, but this hasn't been confirmed yet.
Passenger Compartment Fuse Panel, Fuses:
  • Fuse Amps Description
    30 7.5 ABS
    31 15 Radio
    32 10 Light switch
    33 15 Hazard Flasher
    34 20 Horn
    35 7.5 Interior lamps, power mirrors
    36 7.5 Central timer, electronic modules
    37 --- Not used
    38 --- Not used
    39 10 Reversing lamps
    40 --- Not used
    41 --- Not used
    42 --- Not used
    43 15 Rear wiper
    44 20 Fog lamps
    45 --- Not used
    46 15 Cigar lighter
    47 7.5 Side lights (left)
    48 7.5 Side lights (right)
    49 25 Rear defrost
    50 7.5 Radio, central timer
    51 --- Not used
    52 --- Not used
    53 10 Reversing lamps
    54 15 Brake lamps
    55 20 Front wipers
    56 25 Front power windows
    57 25 Rear power windows
    58 7.5 Air conditioning, recirculated air
    59 7.5 Electronic modules, instrument cluster
    60 7.5 Air bag module
    61 7.5 Light switch
    62 --- Not used
    63 20 Central lock module (on back side of fuse panel)<>
    [st]
    Passenger Compartment Fuse Panel, Relays:
    • Relay Description
      17 Starter
      18 Rear intermittent wiper (may be incorporated with relay 19)
      19 Front intermittent wiper (may be incorporated with relay 18)
      20 Not used
      21 Not used
      22 Not used
      23 Horn
      24 Battery saver
      25 Rear defrost<>
      [st]
      Power Distribution Box, Fuses:
        1 40 Main power supply to electrical system
        2 30 Engine cooling fan (A/C) 2nd fuse
        3 --- Not used
        4 --- Not used
        5 --- Not used
        6 50 Engine cooling fan (A/C) 1st fuse
        7 40 Main power supply to electrical system
        8 30 Ignition
        9 20 Engine management
        10 10 Battery voltage sensor, diagnostic plug
        11 30 ABS
        12 15 Fuel pump
        13 --- Not used
        14 --- Not used
        15 --- Not used
        16 10 Low beam (left side)
        17 10 Low beam (right side)
        18 10 Heated oxygen sensors
        19 --- Not used
        20 10 Engine management
        21 20 ABS
        22 20 DRL (low beams)
        23 --- Not used
        24 --- Not used
        25 --- Not used
        26 10 High beam (left side)
        27 10 High beam (right side)
        28 --- Not used
        29 --- Not used
        64 30 Heater blower motor
        65 --- Not used<>
        [st]
        Power Distribution Box, Relays:
        • Relays Description
          1 Ignition
          2 Not used
          3 Not used
          4 Not used
          5 Low beams
          6 High beams
          7 Fuel pump
          8 Engine management
          9 Not used
          10 Not used
          11 Air conditioning
          12 DRLs
          13 Fog lamps
          14 Stop lamp inhibit relay (AdvanceTrac-equipped cars only)
          15 Engine fan cooling level 2 (A/C)
          16 Engine fan cooling level 1<>
          [st]
which fuse are you looking for Nos2got4me? it would have prolly been easier to just ask first...
My other ride is your Mom
I'll go through my 05 manual and see if there are any differences and post 'em up
Team PITA
paolo,Aug 31 2005, 06:26 PM Wrote:which fuse are you looking for Nos2got4me? it would have prolly been easier to just ask first...
[right][snapback]137916[/snapback][/right]
This is the common knowledge thread, it's not meant for Q&amp;A
