Misc. Mechanical Mods Collection
In this How-To you will find documents on:
- Accelerator Cable Removal
Accessory Belt Replacement
Adjusting MTX-75 Shift Cables
Checking For Vacuum Leaks
DPFE Service and Repair
Finding Your PCM Code
Installing Amsoil Dual-Remote Oil Filter
Remove and Install Zetec Windage Tray and Oil Pickup
Remove and/or Replace Fuel Rail and Injectors
Remove and/or Replace Zetec Alternator
Remove and/or Replace Zetec Oil Pan
Remove and/or Replace Zetec Intake Manifold and IAC Valve
Remove and/or Replace Zetec Engine
Remove / Install the ATX (Automatic) Transmission
Replacing the Thermostat and/or Thermostat Housing
Starter Motor Remove and Replace
Testing the Thermostat<>
[st]
