Steeda Tri-axe
I'm installing a Steeda Tri-Axe short throw shifter in my 2002 ZX5. Everything was great until the step where you are supposed to move the wire for the air bag control module to the left side of the shifter base. Seemed like the easiest part of the install, but that cable wasn't going anywhere. It seems to be screwed down somehow. Has anyone else run into this problem when installing the Steeda shifter?
If memory serves me correctly there are one or two tabs holding the wire to the floor, you just have to yank out the tab(s) and should be able to move the wire.
I replied to you at FF.com on your thread there.
http://www.focusfanatics.com/forum/showthr...p?postid=556791
