Threads: 142
0
if Ford does a diagnostic test to check for problems will this effect my chip?
will they know that i have a chip?
Will it effect thier readings?
Threads: 84
0
wont effect the chip
the chip will change the readings.
it's best to pull it and reset the computer before taking it in!
Threads: 305
9
Just curious what about a car falshed with the xcalibrator, same deal?
Threads: 529
If you're not heavily modded and have an XCalibrator, just revert to the stock program for the day???
Threads: 2
0
If you have a "chip" yes the dealership will pick that up right away , If you have a flash they can see there are changes , If you flash it back to stock origional then they cannot see anything but if they want to check they can tell how many times your PCM has been flashed , If the flash number does not match the Ford flash numbers for your car (how many times ford has flashed your car) you could get some grief
Tom
