Does This Sound Right? Procharger Video.
Since I have never heard a centrifugal blower before I have no clue how there supposed to sound and this doesnt sound right :huh: Now IM hoping its more or less just becuase the dam thing isnt tuned yet :( but it still dont sound right.
I checked the oil in the blower and its full. The belt is running on all the pullies and seems to be ok. I did remove the UDP and put the stock one back on.
Is it possible I tourqed the crank pulley on to much?
The day I put the blower on I didnt touch anything. Stock pullies back on and bolted the blower up and thats it.
Now I did show the video to some one and they said it sounds like the piston hitting the valve??? I dunno how this could be. I drove the car the day before and it was perfect and even had ford check the car and everything was good.
Maybe Im just paranoid. In the video you can totaly tell my fuel map is way out and that why I didnt let it run much LOL Tune should be here soon but I had to start the car just to make sure she was still alive. Maybe im on crack and thats how the cent blower is supposed to sound. Like I said Im prolly the only person in Regina with one so I have no idea how it should sound.
Any way here is the video.
http://www.focuscanada.net/jay.wmv
sounds like its sucking in too much air...but it does sound like 10 time better then my car with the rattling and the vibrating
Maybe post the clip on FocalJet, might be some existing owners who can tell you if it sounds correct.
Done.
http://www.focaljet.com/ubbthreads/showfla...#Post2416804764
Im glad some one posted it sounds normal.
Could be a vacuum leak. What's your idle like? Are the revs hanging and/or then dropping down to where it shakes and cuts out?
I was at Steeda on Saturday trying to get chipped but ran into trouble with some vacuum leaks with my JRSC. Anyways after that we went to the dyno to see a 500 plus HP Mustang get tuned after some boost upgrades. It came in sputtering and smoking like a SOB. Well the meister tamed the beast with earth shattering run at 533 hp!! :o
This took about a dozen pulls on the dyno with a few problems that needed fixing or adjusting. One of the problems was a whistling noise that sounding similar to your procharger sound. One of the guys put there hand over the TB and the whistling stopped. They found a leak at the gasket. The car owner made a gasket out of cardboard and sealed it with some sealant. It appeared to work as there was no more whistling noise and he gained some more HP on his next dyno run.
2013 performance blue ST
TEAM P.I.T.A.
That thing sounds like a freakin funny car or something, with the high-pitched blower whistle.
Ten thumbs up Jay :D
sounds like a nice whistle to me :P
i can't see the vid but just listening.. car sounds like its not really tuned.. kidna like when i put my injectors but didn't have my chip to use them.. ran rpetty much like that
ZX3T gone..
It sounds cool.... weather it's the way it SHOULD sound or not.... I'm not sure.
Jay, they are a bit noisier but not quite like that. It sounds like the belt is on too tight.
The kicking and sputtering is normal, even a little stalling. We had this problem all last year, but now with the changes the car is running mint, except for a tune.
I really noticed at the end of your video when you shut the car down that the engine quit very quickly, and that to me seems to mean that the belt is too tight.
best of luck.
it doesn't sound bad per se.. centrifugal blowers can sound anywhere from a high pitched whine to virtually silent.. a lot of it depends on the cut of the drive gears. Straight cut gears provide more noise than helical...
considering the location and size of the procharger, I wouldn't say it sounds wrong... but only procharger could say for sure.
other than that, your idle seems to be really uneven. is that just a tune issue?
[edit] meford has a point, but I would need to see how quickly mine shuts down to say for sure.... [/edit]
Ya. I cant say to much till I get the tune on. Once thats on I can make another video clip and see if it sounds at all the same.
I could be possible we put the belt on to tight. If you were to take your finger and pull on the belt it wont really move but its on just so it feals tigth enough.
Hmm vacumm leak. Im not to sure. Like I said teh car ran perfect the day before and all I did was bolt on the blower. We did have to run a line from the bypass vavle to a vacumm line reference. Wonder if we ran it to the right line? I will take a picture of the line I tapped into and see what you guys think.
The vacuum line you speak of Jay, on the JRSC, runs off a "t" from the PCV.
This one here goes to a vacumm line right in behind the intake manifold. Same place I think you would tap into if I was putting in a boost gauge. How ever Im sure it was the right line.
Pictures tonight :D
I have no clue what its suppose to sound like.
Sounds bad ass tho.
LOL Sounds like my wet saw with a warped blade running thru super thin tiles
2000 Black ZX3
  Tribal Focus Video.... Mmmm I Love This Sound! ZX3TUNR 22 7,853 12-22-2004, 04:34 AM
Last Post: ZX3TUNING
