Diablo Maf Ai
This look pretty cool
http://focus.c-f-m.com/index.asp?PageActio...ProdID=893&HS=1
[Image: dbl-F7373.gif]
DiabloSport introduces the Ford MAF.ia., the newest device in the DiabloSport lineup. The MAF.ia. allows the customer among other things to use their factory MAF sensor in supercharged or high horsepower applications.
The MAF.ia. is an in-line plug-and-play device that allows you to control one of the most important sensors in your car, the Mass Air Flow meter. There is absolutely no need to cut your wiring harness.
The MAF.ia.'s principal use is to support forced induction tuning. The MAF.ia. does this by recalibrating the signal output from your Mass Air Flow meter.
* No need to cut your wiring harness - MAF.ia. is fully plug-and-play
* Works with both 4 and 6 wire MAF sensors
* 8 user selectable settings for different HP levels (Stock to Gangster level)
* LED indicator of MAF voltage status (shows if the MAF sensor is pegging)
* MAF.ia. also works as a MAF extension harness
TOM actually recommended that to me, its definetly an option for thos going FI. It is actually your best and cheapest option. You also have upgradability....if you start pegging you can just adjust the maf.ia pretty damn cool if you ask me..
Glad that someone is addressing the maf problems with the focus when FI them.
............and ifs a real good solution and cheap thats even better.
CFM is selling them for 139 or was it 159 US??
Not bad at all. Im thinking about picking one up if the SVT mad is going to give me probs.
