Dead Pedal Install
I put a real nice dead pedal on the Subaru and now want to take the plain black plastic pedal I removed and stick it on the Focus for no reason other than, what else am I going to do with it.
So if I drill some self tapping metal screws into the floor/firewall where a dead pedal should go am I going to "hit" anything like a wiring loom or screw anything up in general?
2001 Focus ZTS 2004 WRX
TEAM P.I.T.A. FTW!
I cant see anything being in that area, everything goes directly to the fuse box from the firewall or passing through the door, try using shorter screws just incase. I always wanted a dead pedal. :unsure: B)
Flofocus,Feb 25 2005, 09:48 PM Wrote:I always wanted a dead pedal. :unsure:  B)
[right][snapback]89261[/snapback][/right]
Well then buy one, they can't me more than twenty bucks. :lol:
TEAM P.I.T.A. FTW!
What do you mean by dead pedal?
Its just a place to rest your left foot when you are off the clutch. Here are the stock WRX pedals and my aftermarket dead pedal (far left):
[Image: pedals.jpg]
TEAM P.I.T.A. FTW!
Would rust be a factor Andrew?
Drilling holes through the firwall without treating them might promote corrosion?
Just wondering.
If so, I'm sure a flattened out Tim Horton's cup or pop can would work just as well too.
ANTHONYD,Feb 26 2005, 03:18 PM Wrote:Would rust be a factor Andrew?
Just wondering.
[right][snapback]89429[/snapback][/right]
Fine :rolleyes: , I'll drill it out, prime, lube and then use those plastic pop fasteners things. This is begining to sound like work. :lol:
TEAM P.I.T.A. FTW!
use super glue instead? haha
  Hardkore Dead Pedal Focus man. Focus. 13 3,859 05-11-2006, 08:08 PM
Last Post: Drivesthebeast
