Valve Cover Gasket
I just got 2 issues solved on the Focus. One was slow heat and that just took a
thermostat and the other was the valve cover gasket. I was noticing a burning smell coming through the vents and took it to the garage where thay replaced the gasket.
Anyone else replaced theirs yet ? I have 103,000 km on the car...
Thanks.
2000 Ford Focus
K+N O/E Air filter
Energy Suspension
Transmission bushing.
Medicman,Jan 1 2005, 01:41 PM Wrote:Anyone else replaced theirs yet ? [right][snapback]76975[/snapback][/right]
..I replaced mine each time I crack open the valve cover.
By experience, I've learned that the rubber gasket is not reusable for long. If you plan on doing any cam gear/ camshaft swap, make sure you buy a new valve cover gasket.
Good to know you resolved the smell.
Peace...
[Image: Copy2ofKarlitosig.jpg]
How much was the valve cover gasket to replace? Is it covered under the power train warranty? I am starting to smell that burning oil through the vents and it looks like the gasket has a slight leak with the drippage aimed for the header. :(
2013 performance blue ST
TEAM P.I.T.A.
Werid. I dont even have a seperate gasket for my vavle cover. Its built right into the cover....
ZX3TUNR,Jan 1 2005, 08:09 PM Wrote:Werid. I dont even have a seperate gasket for my vavle cover. Its built right into the cover....
[right][snapback]76988[/snapback][/right]
Same here. You got an 02 right Jason?
Run your car, not your mouth
ZX3TUNR,Jan 1 2005, 04:09 PM Wrote:Werid. I dont even have a seperate gasket for my vavle cover. Its built right into the cover....
..euh OK....?!?
It's a rubber gasket. It is molded inside the bottom part that makes contact with your head.
It is removeable and the same for any Focus from 2000 to 2004. Go and check...:)
Peace...
I did check when i removed my cover and painted it. Its built right in and does not come off.. At least mine wasnt coming off...
..euh OK....?!?
Peace...
[right][snapback]77043[/snapback][/right]
Not true, some very early 2000 Foci had magnesium valve covers and use a different gasket than the plastic valve covers that followed.
..euh OK....?!?
Peace...
[right][snapback]77067[/snapback][/right]
I agree, I have the seperate gasket for my 2000 magnesium valve cover, and on my 2002, the gasket seems to be pushed into a groove that is on the valve cover itself.
  Valve Cover oldeguy 6 2,073 03-28-2007, 12:06 PM
Last Post: oldeguy
  Replacing Valve Cover Gasket habmann 15 7,674 04-10-2006, 04:08 AM
Last Post: Drivesthebeast
  You Might Want To Check.. Water Under Valve Cover DanielB_ZX3 14 6,275 08-24-2005, 02:57 PM
Last Post: ZX3TUNR
  Valve Cover Torque Tantrik ZX3 3 1,845 04-30-2005, 06:47 AM
Last Post: FocusGuy7476
  Burning Oil Is Caused By Rocker Cover Gasket ANTHONYD 30 8,520 02-08-2005, 06:52 AM
Last Post: ANTHONYD
