Buying/installing Clear Side Markers...
First of all, where can I buy a set? Second, is it hard to take the stock ones out and put the clear ones in? Is there a how-to some where?
Ebay is prolly your best bet with these. Quality dont make a difference in these becuase they are all garbage LOL What I mean by that they well get moisture in them. Some ppl are lucky. I was lucky with mine. How ever i fyou take some clear silicone and put some aroudn the edge and make your own seal you are good to go.
As far as install its easy. Easier then easy. Get under the car and use a wrench to take up the two bolts. Disconect the blub (you gotta turn it) then pop out the lense. Install in reverse.
Honestly, no need for a how-to.
Jack up one side (I find it easier and less stressful when you have room to move)
Get under there and take a look.
It will all make sense ;) :lol:
ya its really easy lol its like making toast lol
You dont even need to jack up the car (unless you have it lowered excessively), just stick your face under the bumper and you'll see the two cheapo nut things you'll have to remove.
There's a how-to already made here:
www.jwardell.com/focus/clearcorners.html
As you can see, this mod is probably second only to the shorty antenna installation as far as easy goes :P
The only sort of tough part is that sometimes the tabs holding them snapped onto the bumper are a little stubborn to let go..
Ebay is your best bet for cheapest lenses.. the APC ones are surprisingly expensive, and you have probably a 75% chance they will let in moisture. Mine did, got rid of them and bought some off of ebay, ran a bead of clear silicone around the seam and havent had a drop of moisture in them for over a year.
Ok, sounds good, thanks guys!
Quote:You dont even need to jack up the car (unless you have it lowered excessively), just stick your face under the bumper and you'll see the two cheapo nut things you'll have to remove.
I wish I could get a regular jack under my Focus :( had to go buy some special jack just for lowered cars
thabrat,Oct 22 2004, 03:27 AM Wrote:I wish I could get a regular jack under my Focus :( had to go buy some special jack just for lowered cars
My car is low too....I just drive onto two small pieces of 2x6 board and that gets me high enough to fit my floor jack under my car.
  ... probably the wrong way to do this, but it worked! (Clear Side Markers 2005 ZX5) scottmcleod 8 5,363 07-05-2010, 05:45 AM
Last Post: buzz2.0
  Euro Side Markers Jmountney1 7 3,355 08-16-2009, 12:49 AM
Last Post: paolo
  Grille W/ Clear Markers Casper 3 1,996 02-16-2006, 12:45 PM
Last Post: ZX3guy2000
  Escort Clear Round Side Repeaters Jaspher 7 2,856 06-13-2005, 11:21 AM
Last Post: Jaspher
  Clear Markers And Leather Wheel Cover Jaspher 6 2,343 06-11-2005, 04:39 AM
Last Post: svt_rodg
