Electric Fuel Pressure Gauge Hookup
Hey guys, I'm installing a Cobalt Series Electric Fuel Pressure Gauge from Autometer and I need to know where exactly does the presure sensor goes.\
Does anyone have this installed ??
If you have pics of where the sensor hooks up that would be great.
Let me know how the install went
Thanks in advance
Steeda
14.5@93 (ZEX Wet 55Shot)
I was reading through the autometer install guides when I was shopping around..
is there a t-fitting that comes with the guage? I would assume you could have it anywhere in the fuel line between the pump and fuel rail..
not sure if that's the case with the fuel meter tho.
I took a look quickly at the unit and it doesn't seem to have any t-connectors, but the sending unit. I guess I'll have to do a bit of plumbing to hook it up. Do anyone know if I could hookup the sending unit to the stock Fuel-Rail ?
yes you can, but i recomend you go to a shop and get it done. You need to take the plate off the end of the rail. drill it out to tap it to the right npt size. some brass and your done. if you F@^k it up throw away you rail and start walking to the delear for a new one.
<a href="http://www.apexmodified.ca" target="_blank" class="postlink">[Image: logo_phpBB.gif]
If NISMO is for Nissan Motor Sports, Then HOMO must be for Honda
  oil pressure gauge hook up buzz2.0 2 3,108 11-30-2010, 09:44 AM
Last Post: drunkinmonkey
  Boost Gauge Hookup darkpuppet 6 2,582 10-07-2004, 09:05 AM
Last Post: french_connection
