05-26-2010, 12:24 PM
well does your focus do this? mine is dtec 2.0 w/ stock exhaust and K&N typhon CAI. I clean my MAF regularly each oil change. it's MTX75 w/ stock everything.
- around 3k rpm it will have flat spot, where it seems that the rpm just hover there and no power at all on small and slow throttle opening? ie when ur trying not to speed on 401.
- if you let go of the gas at around 3k rpm or higher and quickly press it again at 3k it will lurch forward??? like when u just learn standard and the engine buck. seems like 3k rpm is a cutoff for the fuel map changeover on ecu or something... iono what I"m talking about...![Sad Sad](//www.focuscanada.net/forum/images/smilies/sad.gif)
- throttle respond is awful and stupid. any fix for this?
![Sad Sad](http://www.focuscanada.net/forum/images/smilies/sad.gif)
