Question regarding SVT Brake Swap
Question
I have started a new thread because some of you may not be following my other thread. I have a issue regarding the e-brake cables. I have installed the cables and where they connect to the calipers there is I am guessing that there is supposed to be some sort of clip to keep them attached. There is a slot on the cable at the bracket in the caliper. I just went to East Court Ford and spoke with the parts dept. and they couldn't see said clip.
For those of you that have done the SVT brake swap what have you done to keep the cables attached? I am going to be taking the wheels off to replace the ABS sensors to see the that solves my other problem (ABS Light on the Dash). And while I am in there I wanted to securely mount the cables. I am not sure if Zip Ties would do the job or not.
Has anybody else had the same issue?
2008 Taurus X to be modded.
Still The Weakest LinkBlush
Did you need a pick of stock svt brakes to compare?
http://www.fordracingparts.com/download/...00-ZX3.pdf
check that out, looks like there is no seperate clip.
it looks like it is part of whole cable assy.
This is what I have. The cables came as a pair in one box. So I now have an extra set, to return of course.
[Image: DSCF3518.jpg]
Wired them to the bracket with mechanics wire. Problem solved. Smile
  Svt Brake Swap tetra 18 4,753 05-27-2010, 03:02 PM
Last Post: Focus man. Focus.
  Svt Brake Swap Ignited83 2 1,737 05-21-2009, 01:24 AM
Last Post: Scorcher000
  Svt Rear Brake Swap Scorcher000 28 8,656 04-06-2009, 08:31 AM
Last Post: drunkinmonkey
