Painting Rims
anyone know where i can get rims painted?
Do it yourself, it's really easy to do.
Grab some high heat primer, some dupli-color wheel paint, and some really fine grit sand paper.
yes paint it yourself..
i painted mine using vht paint and last 4 years before i sold..
i still have 1 spare i painted and still looks fresh..
all you gotta do is to sand current surface bare to metal or until you see primer
[Image: sanding_1.jpg]
[Image: sanding_2.jpg]
[Image: sanding_3.jpg]
apply primer 1 light, 2 med wet coat..
[Image: primering.jpg]
2 light base color, 2 med wet coat..and let it dry and clearcoat 2 light, 2 med wet..
[Image: coating.jpg]
on the car
[Image: final.jpg]
i sandblasted the rims i had on my zx3 then duplucolered them. they looked good id defiantly suggests you at least try it your self first.
worst case your out like $20 and your time
2000 yellow zx3 sold
1994 mazda mx3 sold
1992 ford festiva (RIP)
Duplicolour Wheel Paint is the way to go. Just make sure to use a good self etching primer. Normal primers won't properly bond to aluminum due to the slight layer of oxidation.
thanks for all the tips
  Painting My Stock Rims KillaCamST 13 5,300 09-03-2009, 09:17 AM
Last Post: GFXjamie
  Painting My Rims..which Color? focusonthis88 27 10,038 01-17-2006, 04:10 PM
Last Post: Kelowna_Focus
  Painting Rims ThraxXx 12 3,704 08-09-2005, 05:21 AM
Last Post: Flofocus
  Painting My Rims dmcisaac 8 2,851 04-13-2005, 07:31 AM
Last Post: PpasSFocus
