suspension question
ok so I was just under the car checking all bushings and for anything that could be causing a wiggle, i can't find anything but the front sway bar link seems loose to me, i don't know if there is suppose to be much movement in it? they were just replaced about 3 months ago.
(02-12-2011, 05:27 AM)blue_light Wrote: ok so I was just under the car checking all bushings and for anything that could be causing a wiggle, i can't find anything but the front sway bar link seems loose to me, i don't know if there is suppose to be much movement in it? they were just replaced about 3 months ago.
Usually there is no movement at the ball ends. But only three months old is crazy for a failure.
Did you replace both sides?
Bob
AFAIK there shouldn't be any movement of the the link with the suspension loaded. Ford OEM pieces are really wimpy and easily damaged ... or did you replace them with heavier parts.
i used ford oem part and had the dealership replace them
(02-12-2011, 09:56 AM)blue_light Wrote: i used ford oem part and had the dealership replace them
I just re-read your op ... I'm pretty sure that the first evidence of a loose sway bar is a clunking noise that gets worse over time.
I think it would have to be seriously bad to cause any kind of wiggle while driving and even then maybe not. Do you have any ice build-up on your wheels that might cause an imbalance, or have you hit something that might cause your alignment to be off? Brake rotors too under some conditions can cause a wiggle in the steering wheel. And of course you should make sure your tire pressures are equal on both sides.
the only thing i can think of is i hit a patch of ice and went into a drift and than hit dry pavement kinda hard. iv noticed the rear wheel looks like the camber is out
(02-12-2011, 10:08 AM)blue_light Wrote: the only thing i can think of is i hit a patch of ice and went into a drift and than hit dry pavement kinda hard. iv noticed the rear wheel looks like the camber is out
That might do it ... you should also check your wheel nuts and make sure nothing is loose there.
  Front Suspension Question muttsnutts 19 7,209 09-09-2012, 11:03 AM
Last Post: muttsnutts
  Suspension question. Focus man. Focus. 13 5,091 05-13-2011, 09:03 AM
Last Post: GFXjamie
  Suspension Question Chromey 4 2,751 06-09-2010, 03:38 AM
Last Post: Chromey
  Svt Suspension Question......help imncrxtc 29 10,973 12-08-2009, 08:25 AM
Last Post: NikiterZTS
  Aftermarket Suspension/brakes/ Endlink Question. darkpuppet 4 2,275 01-22-2005, 12:45 AM
Last Post: darkpuppet
