Flex pipe replacement on '05 ZX5
I've come to the forum in hopes to get some ideas from the pros on what to do in my situation.
I've got a broken section in the flexible pipe connecting the exhaust lines to the catalytic converter which goes up to the engine.
It just happens that Ford has made the exhaust manifold, catalytic converter and flexible pipe a single assembly.Dodgy..this means replacing something as simple as a flexible pipe will cost a whopping $700 (only part price) & several hours of labour.
Has anyone else end up having the same issue? Did you replace the entire assembly or do you know of a shop in Toronto that can just weld on a new pipe?
I've attached photos for everyone to get an idea what this area looks like. (got the photos from other websites)
Quick info from this link too:
http://duratec.wikispaces.com/modification-header
.jpg   stockSTheader2.jpg (Size: 44.44 KB / Downloads: 8)
.jpg   img060221-095104.jpg (Size: 91.45 KB / Downloads: 9)
(05-04-2011, 02:55 PM)JoE Wrote: I've come to the forum in hopes to get some ideas from the pros on what to do in my situation.
Welcome - how many km and is your car auto or stick?
Too bad about the flex pipe ... FWIW that price is excellent for the entire assembly you mention.
Have you taken it to an independent exhaust shop? Just about anyone with decent welding skills should be able to cut out the old flex pipe and weld in a new one.
While you're at it you should also address any possible cause of flex pipe failure such as missing or unattached exhaust hangars, or failed engine mounts.
I can recommend a shop in Brampton that I trust ... where are you located?
I was going to say pretty much what ZTW said^^^
Just go to a exhaust shop and have them weld in a new flex pipe.
I have one if you want it. call it $200 and I'll drop it off too you.
This is cause by the rear engine mount flexing too much so upgrade that too.
Ya I have one aswell off my 07 that is under a year old.
Would likely be best to get another manifold and swap it out unless you get a header
(05-04-2011, 10:24 PM)GFXjamie Wrote: Ya I have one aswell off my 07 that is under a year old.
Yours should be a 2 piece where mine is an exact replacement.
It's got 45,000KM on it maybe less.
But if you get a header get a new mount and prepare to have the flex pipe from the new header to have a leak aswell. you'll need a custom flex done for the header is what I'm saying.
see i knew these guys could help you out^^^^ - Johnathan at Cruickshank ford....
  Flex Pipe Replacement drbadskwerl 6 8,451 10-04-2009, 06:25 AM
Last Post: Chromey
  Flex Pipe And Heat Shield DRyanC 5 3,900 09-07-2009, 10:56 PM
Last Post: Focus man. Focus.
  Ebay Flex Pipe Focus Is Art 5 3,099 02-07-2007, 04:07 AM
Last Post: Focus Is Art
  Ebay: Bosal 2.25&quot; Flex Pipe MAlby7 0 1,431 11-18-2005, 03:00 PM
Last Post: MAlby7
  Ok Who Wants In On Trubenz 2.5&quot; Flex Pipe meford4u 3 2,231 10-11-2004, 07:41 AM
Last Post: 01-yellow-ZX3
