Quick Question
Whats a set of SVT gauges worth? Just been offered a set for $100 is that too much?
Remember that when you swap clusters you swap the odometer reading with what you are replacing it with. It is a digital display, but it stores the mileage in the cluster itself.
2008 Taurus X to be modded.
Still The Weakest LinkBlush
(09-28-2011, 09:33 AM)Focus man. Focus. Wrote: Remember that when you swap clusters you swap the odometer reading with what you are replacing it with. It is a digital display, but it stores the mileage in the cluster itself.
Yeah that I know I have changed a couple in the past , and swapped out the board on the back I just wanted to know if 100 bucks was too much or that was the going rate for SVT gauges
Also note that when I went to install a SVT cluster into my '00 ZX3, we couldn't get the tachometer to work right. Not sure if it was a signal incompatibility with my early 2000 ECU or if there was something wrong with the cluster itself. Reverting back to my stock gauges worked fine.
NOTE: the digital test mode tach worked fine (in the odo LCD), but the analog needle tach was wonky and jittery. We even re-seated the tach needle. No dice.
(09-29-2011, 12:11 AM)NOS2Go4Me Wrote: Also note that when I went to install a SVT cluster into my '00 ZX3, we couldn't get the tachometer to work right. Not sure if it was a signal incompatibility with my early 2000 ECU or if there was something wrong with the cluster itself. Reverting back to my stock gauges worked fine.
I will try it out So do you think the price is fair?
  Quick question 07focus_st 6 3,819 01-27-2012, 01:55 AM
Last Post: SL8RZZX3
  Quick Question dabigmandan 4 1,840 05-01-2006, 02:03 PM
Last Post: dabigmandan
  Please Help: Quick Question About Tires. hanserus 2 1,743 02-05-2006, 09:25 AM
Last Post: ZTWsquared
  Svt Guys - A Quick Question NOS2Go4Me 7 2,925 08-30-2005, 01:53 AM
Last Post: bluetoy
  Quick Question (emblems) GlennH 16 5,696 08-26-2004, 10:17 AM
Last Post: GlennH
