clutch..clutch clutch..
i am debating which one i should go for.
for the money, spec stage 3 with 6 pucks is top of my list.
stage3 is cheaper than stage 2(producing cost according to spec rep) but holding more torque.
as you know, my car is on 11 psi boost and dont have number but thinking around 220whp/230tq.
i dont want to have stiff clutch pedal, i dont drive car daily in heavy traffic but i might later.
i want something close to stock.
i heard spec clutch has less clutch pedal travel and engages sooner on the clutch pedal than the factory one.
i havent driven any focus on aftermarket clutch, i am not 100% sure what it means though..
does it means crisp/sharp engagement or engages at higher pedal position?
isnt it bad for clutch life when engages higher??
if you have recommendation on which clutch i should get, please feel free to do so.
My spec clutch seemed to engage very high on the pedal travel compared to stock. Unsure if this is maybe the installation issue, that and everybody who wasn't used to the car pretty much stalled it because it grabbed fast. The clutch pedal was not as stiff as stock, which I found supprising.
Once you get used to it tho, very daily drivable, and when you drive agressivly it grips like no other.
Personally when the clutch in my car fails I'll probably go Spec Stage 3 again.
I loved my spec3, but after seeing the pics from kirk when he was having issues with the tranny, I wouldn't go back to it. The pucks were literary shredded apart. Not sure it it was his driving or what, but it didn't look good at all.
BUT - when I was driving it, I have to echo everything Kevin said. I found it drove better than stock and it grabbed like a mofo.
I am running an excedy stage 1 clutch in my wrx, and its even better then the spec, the stage 1 holds down the 350 torque without any issues whatsoever. not sure if excedy makes one for the focus but I would look at them also...
i also will be needing a clutch soon( by the spring)...let me know what you choose maybe ill get one aswell
(01-18-2012, 11:53 PM)hardk0re Wrote: My spec clutch seemed to engage very high on the pedal travel compared to stock. Unsure if this is maybe the installation issue, that and everybody who wasn't used to the car pretty much stalled it because it grabbed fast. The clutch pedal was not as stiff as stock, which I found supprising.
The experience I had with my Spec stage 2 sounds exactly how Kevin describes above - mind you I was only pushing 200 hp and 180tq but that clutch, combined with the LSD made life on the track very, very, very entertaining.
looks like i m buying spec stage 3 with 6 puck.
only reason i m going with stage 3 is $70 cheaper than stage 2 and 2+.
thanks for inputs!
I love my Spec Stage 3 6-puck. Grabs hard, takes up nice for a built clutch... doesn't let me down.
There's nothing I love more than just being able to shift quick and feeling that clutch hit! Smile
You`re all making me wanna change my clutch too...
not yet...
I need to change mine lol, anyone know anything about the Bully clutchs, Bully is local so just wondering lol
Vehicle: 2002 Focus ZX5 SES
Interior: '00 ZX3 shifter knob, Street Edition cluster, Full Street Edition interior swap
Drivetrain: MBRP Catback
Audio: JVC headunit, 2 10" Sony Subwoofers, Sony Amplifier
Exterior: Rear Wiper Delete, Blackhousing Headlights, 6000k HID's, Stubby antenna mod , SVT 5 Spoke rims, Mach1 front lip
Suspension: Eibach Sportlines, KYB AGX, SVT rear swaybar
thats what kirk went with in my old focus when he replaced the spec.
in the suby world, its very hit and miss with bully.
Thanks nate ill look into it
sounds good, i m going to place an order spec stage 3 6 pucks.
for those remember what i asked earlier about rattling in transmission when car is idling either depressed or not, i found out it was dampening springs were loose.
  clutch/flywheel/differential? konafocuswrc 9 5,173 04-13-2011, 11:53 AM
Last Post: konafocuswrc
  competition clutch for SVTF sonic_mikey 11 5,938 09-16-2010, 08:10 AM
Last Post: sonic_mikey
  Svt Focus Clutch? coolsvt 0 1,150 02-09-2010, 03:01 PM
Last Post: coolsvt
  Brakes Pads/shoes, Clutch patrick23 2 1,580 12-28-2009, 03:19 AM
Last Post: Focus man. Focus.
  Clutch Slipping sweetg 5 2,469 10-07-2009, 01:43 AM
Last Post: sweetg
  Clutch/flywheel Question konafocuswrc 10 3,476 02-27-2009, 03:20 PM
  New Clutch Needed? Alec Brandon 3 2,004 04-10-2008, 02:48 PM
Last Post: silvermist
  Clutch Issues...again... hardk0re 9 3,645 03-16-2007, 05:17 AM
Last Post: ex1z7
  Need New Clutch For My Spi! Suggestions? Dansgreat 3 1,620 01-04-2007, 12:11 PM
Last Post: Mason
  Centerforce Clutch? focusonthis88 4 1,942 03-11-2006, 08:57 AM
Last Post: euro
