New sparco rims
Shocked
Has anybody seen them on tire rack. bright green, an bright red?
I think i might go with the red, an opinons on how this will look on my yellow zx5?? Or perhaps even bright orange?
Are you talking about the assetto garas?? I almost bought a black set but decided to with the kazeras.... Just beware getting your tires mounted from tire rack! Order four rims (17x7.5) and four tires (215/40/zr17) two out of the four rims had pieces of the finish chip off while mounting, and they actually split the sidewall on one of them because they dont use enough lube so the low pro tires end up binding on the mounting tool. Not big of a deal as they shipped me a new tire. But save your self the trouble and just get a local shop to mount!
Yea I was just going to order the rims because im not sure what kind of rubber im going to be putting on them.Plus I live like 25 min away from michigan so I was just going to take them over there to get tires.But thanks for the heads up .
(02-16-2012, 09:17 PM)MuskokaZX3 Wrote: Are you talking about the assetto garas?? I almost bought a black set but decided to with the kazeras.... Just beware getting your tires mounted from tire rack! Order four rims (17x7.5) and four tires (215/40/zr17) two out of the four rims had pieces of the finish chip off while mounting, and they actually split the sidewall on one of them because they dont use enough lube so the low pro tires end up binding on the mounting tool. Not big of a deal as they shipped me a new tire. But save your self the trouble and just get a local shop to mount!
I second that!!!! Buy rims only and have a shop run them on a balancer first to see if they were damaged or dropped during shipping. Then take pics and video for proof
Do you think the bright green would go with yellow? I want my car to stick out lol.
