Ebrake Light
Ebrake light keeps flashing while driving.
And no the ebrake handle is not being pulled or moving Smile
Sensor?
Please let me know what you think.
(07-11-2012, 11:35 PM)Chromey Wrote: Ebrake light keeps flashing while driving.
Sensor?
IIRC the brake light not only indicates the e-brake is on, but also is used to indicate problems with the braking system in general - you may for example want to check your brake fluid level.
i had the same prob with my mazda and the rear brake was leaking and made the brake fluid low
I had this problem with my 2000 ZTS, the drum brake wheel cylinders ( I think that's what they are called) leak. Check your brake fluid levels.
2000 White ZTS: retired
K&N Filter.....
I have no leaks But my fluid is at the Min line.
Ill fill it and see what happends.
most likely, you will need to get rear drum serviced.
(07-12-2012, 01:45 AM)konafocuswrc Wrote: most likely, you will need to get rear drum serviced.
Was thinking that, They have never been touched, 125XXXKM
rear drum=wheel bearing change as well. BTW, buy the drums from Ford. At my work we've had nothing but headaches using anything aftermarket.
  Flashing And Dimming Ebrake Light girard.k 8 3,068 04-08-2007, 01:54 AM
Last Post: ZED_not_zee
