11-15-2012, 09:43 AM
Where are my Ottawa , Bretheran , I need a little help , if any of you are mechanically inclined.
Thanks
Greg
Thanks
Greg
Ok Crazy Canucks...
Thanks Greg
11-15-2012, 02:57 PM
What's wrong?
11-15-2012, 03:01 PM
the car shakes when accelerating , I have CEL for EGR system, Both are plagueing me and i can`t find a source.
Car shakes when accelerating , worse around 80-90 then dies off over 100. , it feel all rear end . i changed the rear wheel bearings , and links. no change. CEL for EGR system - by all accounts should have been a DPFE sensor , but i changed it and i still get the CEL for the same thing , Checked all voltages for EGR system and all come back fine. I can only think that it make my the actual EGR valve its self. But i am at a loss , kinda don`t want to throw money away on maybes , so if i can atain some help from local focus folk to make my life easier i would be appreciated.
11-15-2012, 03:43 PM
Check the tire wear.
11-15-2012, 03:45 PM
tire wear is fine. nothing that would cause the shakes i get . The shakes aren`t violent , and i don`t think the car will tear itself to pieces but it is bothering me that i can`t find a source.
11-15-2012, 03:49 PM
Well it could be a number of things. did you check the motor mounts? Does it shake when youstart it up?
no , at idle and slowing down is fine , its accelerating , i thought the same , but hard to see that when the shakeing is coming from the rear end.
11-16-2012, 05:28 AM
Shaking from the rear? It would either be wheel balance or wheel bearing.
Is it at a specific speed, or during acceleration at all times?
11-16-2012, 05:56 AM
(This post was last modified: 11-16-2012, 05:58 AM by incognito27.)
Acceleration all the time. Honestly if your local if you experienced it , it would be a whole lot easier to explain. The shakeing started before i got the rims and tires i have now , and continued after i had them balanced and installed. I also just replaced rear drums and bearings , and it is still doing the same. i also replaced the sway bar links. to no avail .
Greg Edit: No saying that , just because it feels like its from the rear end doesn`t always mean it is from the rear end. I have experienced in the past when i worked in a shop , that sense of feeling can be a little deceitful
11-16-2012, 02:27 PM
What part of town are you in? I live out in Kemptville, but I work near St. Laurent and the 417 if you wanted to meet me by work sometime.
-Ryan
11-16-2012, 02:29 PM
I live in nepean , close to the hospital almost to bells corners , i can meet you there , what is he place called and when
11-20-2012, 07:12 AM
11-21-2012, 02:08 PM
(11-20-2012, 07:12 AM)incognito27 Wrote:(11-16-2012, 02:27 PM)reldridge Wrote: What part of town are you in? I live out in Kemptville, but I work near St. Laurent and the 417 if you wanted to meet me by work sometime. This week is shot. Maybe next week some day? Where do you work?
11-21-2012, 02:10 PM
I work everywhere
« Next Oldest | Next Newest »
